Chain fence eating turbo
Is a 3.6 as robust as a 3.2/930 for big turbo power?
Always wondered how much power a 3.6 can take with stock rods and crank (head studs?) barring you stay at the OEM redline.
On a side note, I have a 3.2 converted to 3.4 (est. 600+hp), but long sometimes for a really big bore engine nudging close to or at 4.0.
Is this super exotic or the same as going from 3.2 to 3.4? Just P's & C's?
Will a stock 3.6 and up take around 2 bar of boost if one chooses, or will the cylinders be hand grenades at this point?
Really curious. TIA.
Old 01-03-2015, 09:24 PM
Sub"d
Old 01-03-2015, 09:38 PM
totle's Avatar
Hi Tippy,
Guess you are decreasing the CR?
A friend here in Norway build a 3.3 or 3.4 out of a NA 3.6 by installing a 3.0 crank, it gives a CR of 8:1 (or was it 8:5:1 ?)
He says that the 3.6 P/C are very good. He makes 5-600 hp with 3.0 crank and 964 cams
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 01-04-2015, 03:21 AM
Hello Totle, yes I have Max Moritz pistons and Mahle cylinders dropping down to 7.5:1 CR.
Old 01-04-2015, 05:40 AM
Turbonut
Raceboy's Avatar
Isn't 7.5:1 too low? With todays engine management, I would not go below 8.5:1 to get the best driveability...
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 01-04-2015, 09:45 AM
