3.0 MFI build by www.tech9.ms
We recently completed this 3.0 engine to be used for Tarmac Rally events in the UK and Europe.
I also run a similar single plug version in my grey 911 SCR that is successful as a circuit racer and tarmac/tour event rally car here in the UK I thought the details may be of interest to some of the readers here Engine is based on a 911SC, aluminium block (930/10) - retains 3.0 Capacity Layout of components, prior to build https://farm8.staticflickr.com/7515/...1c4efb0a_c.jpg Tech 9 Custom pistons and conrods https://farm9.staticflickr.com/8562/...3c133755_c.jpg Mahle Cylinders, machined for accuracy (bore perpendicular to mounting faces) then plated with ceramic composite https://farm8.staticflickr.com/7505/...5c93c1b1_c.jpg Cylinder heads twin plugged and new sodium filled Intake and Exhaust valves installed https://farm8.staticflickr.com/7485/...e3a31231_c.jpg Ports machined for flow and accuracy of mounting to intake manifolds, Injector ports added for MFI injectors Heart of the beast ! – here you can see the large capacity GT3 Oil pump, one piece steel Intermediate gear, Crank and con-rod assembly, cases with shuffle-pins installed on the main webs. To ensure this lot don’t burst out, secured with ARP Porsche specific engine fasteners throughout https://farm8.staticflickr.com/7574/...84c709d9_c.jpg Build completed https://farm8.staticflickr.com/7504/...78f403f0_c.jpg Details, Details……. Magnesium High Butterfly 50mm Intake system, MFI Red Top RSR Fuel Pump https://farm8.staticflickr.com/7536/...ba79a149_c.jpg Pre-Dyno – Installed on our engine test bed to bed in camshafts and set ignition timing, set throttle butterflies etc https://farm8.staticflickr.com/7570/...5286fe13_c.jpg Dyno testing – Final results 308bhp @ 7600rpm with 233 ft/lbs torque @ 5300rpm with silencing requirements met to allow for MSA event testing Built as a rally specification engine with good low-mid range torque characteristics, the torque curve is very flat. In race/circuit specification the power output would be closer to 340bhp https://farm8.staticflickr.com/7542/...acf468b7_c.jpg |
Tech 9 Custom exhaust system with equal length stepped headers, with merge collectors
https://farm9.staticflickr.com/8653/...3086d14e_c.jpg Ports machined for flow and accuracy of mounting to intake manifolds, Injector ports added for MFI injectors https://farm8.staticflickr.com/7510/...50707457_c.jpg https://farm9.staticflickr.com/8640/...fae87114_c.jpg |
Beautiful!!
I'm at the tail end of a similar build, but mine will be on carbs. What is the finish on your fan?
Great work! |
Looks wonderful! I like the 308hp from 3.0L, what comp ratio? any other details welcomed. Thanks for sharing.
The fan and housing is finished by careful Vapour blasting the original magnesium parts, then we apply the Chromate process, that gives the wonderful period look. This can only be used on Mag casings, not Aluminium. |
Wow, that is a thing of beauty!
Let me ask an uninformed question: why choose MFI over other options? Seems most guys are doing carbs and EFI with these ITB setups, but I'd love to understand more about going mechanical. |
The efficiency could be improved using modern technology, but for historic competition use where the events are regulated and compliance with FIA Homologation, then modern intake systems are not allowed. There is also the rarity factor to contemplate, when this engine is installed into any vehicle, its both a talking point and adds desirability/value to the vehicle in question. It's not a cheap exercise installing this system, and for a vehicle that is not being used in FIA events you could save $$$$'s by using a modern system, but as always with anything in life, I guess its down to personal choice and budget consideration. |
For anyone that wants to hear what this engine sounds like, a short video to entertain !
In-Car Tour Britannia - SCR 3.0 | Tech9 News! | Tech 9 |
Sounds great! |
Thanks for the info. The sound definitely lives up to the beautiful engine. :)
I would be interrested in a similar exhaustsystem only for a slightly bigger engine.
Reg. Nic |
nice, very nice
I'm interested in the shrouding - where do you source that from? Nice build - very clean.
It's not easy getting the 'honey' coloured material to look correct, it also gets better with age, as the set on my engine approaches 3 years old |
we have built a number of these engines since this thread was posted
all parts available from stock to build new complete engines, or we can supply short motors for final completion to desired specification |
I assume you also do full builds with EFI and the associated tuning? |
yes, we can assist with standard, concours or bespoke engine rebuilds from 356 to 997 |
Work of art!
Very Nice!
What size tubing is the exhaust header made from ? |
| All times are GMT -8. The time now is 01:38 AM. |
