Guest
Posts: n/a
Help ID these jugs
They've been in a box in the garage for years and I can't remember what they are or how I ended up with them. They are stamped 84 std and have wrist pins. Any idea what they are and their value? I'm thinning out my stuff. thx
Those appear to be either 2.2T or 2.4T pistons and cylinders. There should be a casting number inside the piston that will begin with 84P. The cylinders look to be 84 mm cast iron. They will have a casting number near base.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Pelican shows those head gaskets are for 1970-73 911. 2.2L - 2.4L as Tom says.
Guest
Posts: n/a
Thanks - The jugs are painted black outside, so I doubt they're Mahle. I'll take a look at the skirts.
Check the bores with a magnet; they might be some kind of Biral-type cylinder. QSC maybe?
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Straight shooter
I doubt QSC.
The clips aren't what QSC uses and they don't machine the groove for the CE ring on top last I checked.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
