Driver's License Owner
The Watson's Avatar
What is this case hole?
See yellow arrow below.....This hole was not being used when I tore apart my engine. Is this the location that should have a bolt and nut (with 2 washers)? If so, anyone know the bolt sizing, etc? Wondering why also.
Thanks -- Chuck
1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700
Old 01-22-2015, 01:29 PM
yes, that is the location with the bolt. I will have to check the size.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 01-22-2015, 03:47 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Yes there is a M8 bolt and lock nut that goes thru the case there. Reason for the bolt is because of the oil gallery location that is just above and to the right of the subject bolt hole. That bolt helps ensure a good seal for that oil gallery. Bolt length is typically 45mm or 55mm long
That oil gallery is a very important one. It's the one that feeds the entire engine, like the trunk of a tree feeds all the branches.
Kevin L
'86 Carrera "Larry"
Old 01-23-2015, 09:29 AM
The Watson's Avatar
Great - thanks guys.
Thanks -- Chuck
Old 01-23-2015, 11:19 AM
