Porsche 3.2 Cylinders restored?
Hello. Does anyone know a shop that can restore Porsche 3.2 Cylinders preferably in Florida. Thanks in advance.
Project Addicted
If you mean replate, then there are just a few places that I know of. I have used and would recommend Millenium Technologies in MI to do this for you. All of this will depend on the type of cylinder you have. Nikasil or Alusil. You can usually tell by who made them as to what coating they have. Other will know much more than I.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
This being a 3,2 I would assume nikasil, but you should never trust assumpions... |
It is relatively common practice to Nikasil plate onto Alusil Cylinders, clearly having ground the cylinder first.
We have only run these cylinders with Aftermarket pistons and rings to suit Nikasil cylinders (Woessner) but I believe you can fit Goetze rings to KS pistons and they run well. There is a small difference in expansion between the KS piston and the Mahle piston so making sure the clearance is correct is important. |
Thanks guys! I really appreciate the info. I'm having trouble with he guy that rebuilding my engine. Any recommendations for Florida?
Project Addicted
Full on rebuild or just the top end??
The top you can probably do if you have some skills, but the full engine should prolly be sent out. I can't help you there.....
I have 0 skills
and want to do a complete rebuild.
Forced Induction Junkie
Haven't used this company yet, but plan to send out some C2 Turbo cylinders to them in the Spring. Like any automotive machining/services, find references and go from there......
Plated Cylinder Services | Plating Honing Repair | Piston Coating | Big Bore Kits | Motorcycles | Snowmobiles | Dirt Bikes | Rebuild | Replace | U.S. Chrome Corporation of Wisconsin Cylinder Repair Company
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
US Chrome did a good job turning my 95mm Alusils into Nikasils. Plenty of experience.
For an engine rebuild in Florida I would contact Mike Bruns of JB Racing. They are near Orlando.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
+1 for JB Racing
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
We can replate and rebuild your motor. Nikisil is a trade marked name so the replated cylinder surface has a different name. Goetze rings will work just fine. Are you trying to go oversize on your engine?
We are on the east coast by the way. Last edited by DSPTurtle; 02-15-2015 at 06:14 AM.. |
No, just trying to have it rebuilt and show looking condition.
TURBO... suggest you speak with George at GP Autowerks. He's in Miami. Specializes in Porsche. 305-267-0516 (He's oldschool... no website.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Ok. ˆll look into in tomorrow. Thanks.
