putting my 3.8 back together.
I just replaced the bearings, rings and all new seals in my 3.8 rsr motor. thought I'd share a few pics.
The motor is from my 914 track car. 12.5:1 comp. twin plug, endurance RSR size valves, Web Cam 171/149, cams(center drilled), carrillo rods, ITB's with motec efi and more. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Looks sweet!
That's got to be a beast in a 914! What are you putting to the wheels? Mike |
motor
Hp should be around 380-400 car weights 1,920 pounds.
Hey man!
Cool engine! What part number crank case do you have? Best regards Per-Stian |
964 rsr case. m64/04
SCOOTER... nice work. Seen a few 914-6s... yours is tops. Clean set up... very nice. 3.8 in that weight is g-force terrific. Compliments.
Looking at your config brings back very fond memories. Worked on a rear end mod for a 14-6 with a similar high wing like yours some years ago. Using your 6 as base, it looked like this (below.) I know some like visual mods and others are offended. If offending, I'll delete.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
No offence taken. looks good! Yeah the HP to weight is crazy. I just did a full engine rebuild, tranny and suspension. I also installed new seats, fire system,all new brakes, al new oil and fuel lines and wevo shifter. I should be good for a few more years...
Always loved this car and a bit famous,was an Excellence feature car years ago,remember it was built on a heafty budget,very nice.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Yeah, I bought it a few years ago. I have the excellence issue from Nov. 2002 I contacted the original owner last year just to touch base.... Nice Guy!
The car only has about 137 hours since the build in 2001.. I just figured i'd freshen up everything this winter and hit the ground rolling this spring. |
German Blood
Where do I buy one? The highly molested 914 doesn't get enough cred. What's it like to drive this thing? Please use as many analogs to lawn tools as you can.
'86 3.5L TP Coupe |
Nice looking Engine but those Rods I believe are pauters not Carrillo's from the looks of things.
bob |
