| Registered User |
				Valve adjustment on a 71 t
			I recently adjusted the valves on my 71 911t and now the car will not start.  The engine turns but it's not firing.  Any idea what the problem might be?   | ||
|  04-19-2015, 07:46 PM |
| Registered Join Date: Jul 2001 Location: Suntree, Florida, USA
			Did you double check that you got the plug wires seated correctly?
|  04-19-2015, 09:06 PM |
| Under the radar Join Date: May 2007 Location: Fortuna, CA. On the Lost Coast near the Emerald Triangle
			Did you remove the distributor rotor?  Check for spark.
				__________________ Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage | ||
|  04-20-2015, 11:33 AM |
| Registered Join Date: Jul 2012 Location: Simi Valley, Ca.
			The first thing I would check for is spark. While adjusting the 1-2-3 intake valves, you could have knocked something off on the electrical panel to the left? Bob B | ||
|  04-20-2015, 03:33 PM |
