Before your newbie rebuild, did you buy every tool you needed?
The tool list is expansive and expensive as Im about to start my 964 rebuild. Did you buy every tool on Wayne's list in his book or are there substitutes? Which are absolutely necessary and which can be substituted with more ordinary tools? Thanks
1980 911SC Targa 3.6L |
Tools
Ive been building for 35 years and I'm still buying tools to make it easier.....
Bruce |
Straight shooter
Yes, I bought every tool before I started even removing the engine from the car. No use losing time that can be avoided.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Under the radar
I already had a prety good selection of tools. I did buy and made some of the special tools needed. Like the flywheel nut tool and the cam holder.
Here is my current project.
abides.
My biggest regret was missing out on the $500 ultrasonic cleaner that was posted a while back. That would have saved me a fair amount of time and money.
If you look, you can find some affordable tool substitutes. For instance: Stuff that worked well for me: -Harbor Freight Digital Indicator - $30 instead of $83 (requires a different threaded tip, 4-48 thread, 1.5") -QSC cam bar - $68 vs $85 for SIR cam bar -QSC engine yoke - $200 vs $300 for a real P201. -Harbor Freight Torque wrench - $11 each, work fine. - make your own rod and chain holders from a $10 sheet of steel -Goodson Stud Remover (head studs)- works well and cheaper than Snap-On (heat the case with a torch). Thanks to KTL for the suggestion. -Wiseco ring comressor. Easy to use, works well. Thanks to Gordo for the suggestion. Avoid: -Harbor Freight Digital Calipers. Not Precise enough to be useful, IMO. I borrowed a pair of Mitutoyos from work in order to double check rod bolt stretch after using the ARP stretch gauge. -Three wheel engine stands. Mine was rated at 750 lbs and was a little tippy. ![]() That said, buy your SIR tools from Pelican... other sites that appear to sell them cheaper do not actually have the parts in stock, and the backorder wait can be months long.
Graham 1984 Carrera Targa |
hey gtc which cleaner was this? i just bought one and i think i may have gotten in on that deal. retail on the one i got was $1400 and i paid $480
1967 911 (Azzuro Thetys) - #308439 1971 911 (PTS Black) - Built 3.6 Sleeper 1989 911 (Grand Prix White) - Cabriolet Bone Stock |
abides.
The one from this thread. Big enough to do a cam tower:
Excellent Part Cleaner Looks like it was actually $380, not $500... rubbing salt in my own wound...
Straight shooter
Great suggestions... Except I tried to buy all the cam tools from Pelican at once and was able to check out. Later checked my order status to find they were back ordered... Cancelled that and found them far cheaper on eBay.
i ordered the 30liter one over the weekend. they're normally $1400! but i got it for ~$500 due to a price f'up on their part. luckily for me they said they'd honor the price and immediately took the ad down!
For my experience you will need
Cam tool Z block Torque wrench Metric dial indicator The rest is pretty standard For the exhaust Alan nut I just used a regular Alan key than as a handle for it used a socket and and extension |
non-whiner
I just bought this 30L ultrasonic cleaner for $425.
"Too much is just enough." |
wow thats a huge price diff mark. how do you like it? i tried to find some reviews on how well it cleans. any pointers on cleaning solution?
Kartoffelkopf
Well, firstly a confession - I love buying tools....there's no such thing as wasting money on them, so I already had a very comprehensive, decent quality Britool setup from previous projects
But having said that, I do baulk sometimes at the cost of some one-time-use items. Some you'd waste more time trying to cobble together, than simply buying, e.g., I got a pretty good deal on a once-used cam tool for the 964 - even with shipping from Canada (eh) to the UK, it was just over half price. I also bought (from our hosts) the basket and a lifting bar....not the sort of items I want to fanny about with. Then I made the speciality tools like: The gudgeon pin spring insertion tool The chain holders (to hold chains vertically whilst assembling case halves) A holding plate to mount a magnetic based DTI for cam timing (although if needed I'd do this with a Z-block tool next time) Valve spring height setting tool If you wanted to do the same, browse through my build thread below, it's all documented in there. ....but like the guys above ^^^, wish I'd investigated further the ultrasonic cleaners...next time, perhaps. I think next time I'd also buy a chain tension setting tool; I "got-by" without, but it took quite a lot of effort to get the correct tension, and of course isn't 100% repeatable.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
It's a trap...
PVC pipe to hold the cylinders on. Don't need the Cylinder Holding Nut Set.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). Last edited by Speed Buggy; 05-05-2015 at 06:03 AM.. |
I have made a ton of tool purchases since I started my engine rebuild. The thing that makes me the most pissed off is because I have no experience doing this, there are setbacks and delays in making progress because I don't have a stud remover or a ring compressor. I am learning as I go. Hence, I am constantly buying tools to help me do this. I tried to put together a short list prior to getting started and I had enough for simple teardown but now that I'm going back together there are things that I've had to buy along the way. I also probably take too long researching which tool to get. I know I will eventually get there but it can be frustratingly rewarding times.
Mike '89 CARRERA #402 |
speed buggy--can you elaborate on the pvc pipe substitute for the cylinders? Thanks
Thanks everyone I just ord'd these from Pelican: Dial guage (metric) Feeler gauge .004 Zblock Chain sprocket holder Cam socket Acid brushes 12pt 12mm socket tool 1/2" drive
It's a trap...
I think it is 1/2 " PVC, someone else may be closer to their garage, but you cut it to length and use a nut to hold your cylinders while you rotate the engine.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
It's a trap...
All the cool stuff I learnt about Porsche shortcuts, I learnt on here. Read through the threads about rebuilds. That is where I saw this and many others, such as the flywheel holding tool made out of a piece of barstock. Drill two holes, one on each end, and then slip over a trans mounting bolt and a bolt in the flywheel (pressure plate bolt I think), loosen and tighten flywheel bolts.
Registered Loser
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320 Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180 |
Sorry to be late to the party...
http://www.amazon.com/gp/product/B0009OR93I Ring compressor. Our pistons are tiny and light, the wrinkle style compressor gets a tight fit on the rings without being bulky like so many tool built for big fat cast American style pistons. Also, this one is very lightweight, has a small handle (which is important with all of those head studs in the way). Worked a charm on my rebuild. I also use a leftover 13mm wrench as a flywheel lock, even easier and faster than drilling bar stock
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
