Trick question
Hello to all honorable forum.
i have a trick question ......my case is *6403090* and i have the craziest idea
can i fit 107 mm liners and turbo piston from 993?
will it fit? do i need to change the heads as well?will it work with 930 single turbo headers?
please say and write all you think of give me all of your knowledge
THX
Old 05-25-2015, 11:19 AM
fred cook's Avatar
Cylinders..........
I would give the guys at LN Engineering a call. They can tell you what can be made to fit and what can't. I know that they make slip fit 100mm cylinders for the 3.0 and 3.2 liter blocks. I think that everything from 102mm and up requires machining the spigots in the block. Good luck building your monster motor!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-29-2015, 03:34 AM
mskala's Avatar
6403090 would be a 914-6 case. So, unless you have a typo, I'm going to say no
chance.
Mark S.
'70 914-6
Old 05-29-2015, 07:06 AM
Walt Fricke's Avatar
If a 914-6 case (basically same as the T), not a chance. 93mm is as wide as you can go. The 3.0 cases have a wider stud spacing, which allows the spigot to be wider, which allows wider cylinders.
Old 06-03-2015, 08:45 PM
