Possible to use two different case halves
Is it possible to use two different 3.0 case halves on a rebuild.One of mine is damaged
Old 05-07-2015, 09:38 AM
Try not, Do or Do not
Henry Schmidt's Avatar
It is possible.
You will need a good method to measure main bearing journals for ovality and well a intermediate shaft journals.
The cylinder base deck will need to be checked as well.
A qualified Porsche machinist can correct any inconsistencies that may exist.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-07-2015, 09:46 AM
Thanks Henry.
Old 05-07-2015, 10:13 AM
I still might ship that other case to you if your still up for it?
Old 05-07-2015, 10:18 AM
It's your call. We're here if you need our service.
Henry Schmidt
Ph: 760-728-3062
Old 05-07-2015, 04:46 PM
