2.4 cam timing question
I pulled my 2.2 that was converted to a 2.4 and replaced it with a fresh 3.0. My brother built the 2.4 and apparently he missed a few things while building this engine so I am going to take it down to the block but not split the case and reassemble it (I hope he doesn't read this!). The reason I am going to take it apart is that it has several leaks and I see red silicone between the cam housings and the block plus at least one of the chain ramps are on backwards and it has what looks like home made solid tensioner which I will replace.
This is what I know (have been told about the engine). It is a 2.2 that has been stroked to a 2.4. It has S heads (can see the part number), I am told it has 10.5 compression, and S cams (the end of the cams have an S and a dot on them).
My question is, when I reassemble it what should I set the cam timing to?
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 05-06-2015, 05:52 PM
Set the cams to "S" spec then check clearance to the piston.
Bruce
Old 05-07-2015, 03:17 AM
What is spec?
Tom Feeney
1970 911 T
1973 911 T
Old 05-07-2015, 03:18 AM
bgyglfr's Avatar
Get Wayne's engine rebuild book. It has the specs and instructions on how to set the timing. You will also need a dial gauge.
70T 2.7RS spec.
68L coupe
Old 05-08-2015, 01:55 AM
I have the book. I guess I need to look at it again.
Tom Feeney
1970 911 T
1973 911 T
Old 05-08-2015, 04:20 AM
Found it... 5.2
Tom Feeney
1970 911 T
1973 911 T
Old 05-08-2015, 08:26 AM
