Possible to use two different case halves
Is it possible to use two different 3.0 case halves on a rebuild.One of mine is damaged
Try not, Do or Do not
It is possible.
You will need a good method to measure main bearing journals for ovality and well a intermediate shaft journals. The cylinder base deck will need to be checked as well. A qualified Porsche machinist can correct any inconsistencies that may exist.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry.
I still might ship that other case to you if your still up for it?
It's your call. We're here if you need our service.
