2.5E port size?
I'm just finishing off my build list and could do with some recommendations for port sizes.
The car is a 911T and is mostly hot street use. So far I have the following:
86mm 9.5:1 Pistons
E cams
MFI pump has been reworked to E spec
I'll be using T stacks until I can afford and get E ones (or find them!).
So the question is, what size shall I open up the ports?
Should I open the throttle bodies to 34, Intake 34, Exhaust 34? or 32 all round like an E or something different.
I really want to keep the torque in lower rather than peeky power of an S.
Any input would be great as I need to tell my machine shop soon!
Old 05-10-2015, 04:42 AM
Rads,
T & E engines use the same size ports, valves, throttles & intake stacks; only the cams and MFI pump varies.
If you want to retain maximum torque & throttle response, keep the heads stock.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-10-2015, 09:40 AM
Originally Posted by Steve@Rennsport View Post
Rads,
Thanks for getting back to me Steve.
I've measured my intake and TB's and they are 29mm, I thought E's ran 32?
Old 05-10-2015, 10:54 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I assume (86mm /2.5) that we are talking about a 72-73, 2.4 T.
You are correct, T and E have different throttles, ports and stacks.
The T has 016 stacks, the E has 014 stacks and the S 012.
The ports are as you elude. 28/29 vs 32 for E vs 36 for S. The throttle housings match at the port.
The engine (86x 70.4) is actually a 2.45. I build them all the time. This engine likes to breath.
My recommendation is to port it to 36mm, run E or S stacks and match the throttle housing to the port, 36mm.
I would also take the E cam and have John @ DC cams grind them to Mod Solex. You can do this on E cams very easily.
The results will be a great little engine that will make good torque and great horse power all the way to 6400+. It's a fun engine to drive.
We have the stacks in stock, can modify yours (bore them out) and modify the throttle housings with an incredibly quick turnaround.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-10-2015, 11:32 AM
Almost any size you want, quick and easy . Generally within two weeks.
We can even repair damaged plastic stacks, within reason.......
Henry Schmidt
Ph: 760-728-3062
Old 05-10-2015, 12:30 PM
Thanks Henry. You are right about the 2.45, they P&C's came from you.
I Will have to have a think of what to do now, as the engine you mention sounds great but, my budget is tight and didn't really want to spend more on cams.
Good to know about the Stacks, I should have got you to pop a couple in the package you've just sent me with the 4 rib oil pump!
Old 05-10-2015, 12:37 PM
I would rather be driving
jpnovak's Avatar
Henry your wine shelf needs to be restocked.
Old 05-10-2015, 02:03 PM
3 restos WIP = psycho
kenikh's Avatar
Mod Solex, 36mm ports and stacks, cam timing slightly advanced, ZOOOOM.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-10-2015, 02:39 PM
Under the radar
Trackrash's Avatar
FWIW. I have a SS 2,5. 66 stroke 90mm P&C. 8,5 CR. I'm running E cams with Webers.
I ported my heads to 35mm intake and exhaust. Great running motor. I can hit the 7300 rpm limiter in second gear and the motor is still pulling.
If you want a real screamer, I would use S cams with 35 to 36 mm ports. Depends if you want lots of top end for a track motor.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-10-2015, 07:23 PM
I read a post about it being difficult to get the DC30 and MFI pump to work, thus my switch to an E Cam for safety!
Old 05-11-2015, 03:07 AM
So if we assume that I stick with my E cam for now, is the general consensus 34mm, 35mm, 36mm!?
Old 05-11-2015, 03:16 AM
356RS's Avatar
34mm if your keeping the E cams.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-11-2015, 07:12 AM
If you are truly struggling with .080'"in your decision process, make the best compromise.
Port the heads to 36mm and port the throttle bodies to 34. This transition can even help the control intake pulses. The difference is minor but if you decide you want more top end, all you do is convert (bore) the throttles and change the cams .
No need to remove the heads to enhance your performance.
Henry Schmidt
Ph: 760-728-3062
Old 05-11-2015, 09:14 AM
Thanks Henry and everyone, I think I have a plan!
Old 05-11-2015, 01:07 PM
