It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Cool Ahh, its finally in...G-rated
Got the engine installed this afternoon. Thank you to my sons for the help. Hoses and electrical tomorrow. What do you guys do with the old gas you take out of the tank? Lawnmower??
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 05-11-2015, 07:09 PM
Straight shooter
Lapkritis's Avatar
How old? Lawn mower eats anything I drain that still burns.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-12-2015, 09:25 PM
porschetub's Avatar
Love that comment ,IMO there is too much BS about old fuel,recommissioned a car recently with really old gas ...smelt funny and was a wierd colour when doing oil and fuel filter change,fired up straight away (CIS injection) no probs.
What can cause issues is old fuel in the motor as it gums up stuff if sitting for long periods,if not happy top up with fresh stuff and a bottle of octane booster all will be good.
Having said that any moisture is the enemy with a part full tank over time....now that can cause big problems to the fuel distributor and injector pintels .
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-13-2015, 12:31 AM
tharbert's Avatar
I'll agree there was too much BS before "we" started adding ethanol. Now, with the blended gas/ethanol, the fuel becomes extremely hygroscopic and in addition to gum from evaporation during storage, you have the propensity for corrosion especially on brass, aluminum and copper. As a side note, ethanol is a strong solvent and will attack hoses and seals not originally engineered for use with blended gas. I think, these days, you are better served removing the fuel or bolstering it with fresh fuel rather than just firing it up with crossed fingers.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 05-13-2015, 06:42 AM
It's a trap...
Ok. Thanks. I don't know how much is in the tank. Thanks for the info. I'm leaning towards top off and dry gas.
Old 05-13-2015, 07:51 AM
VFR750's Avatar
I just recently removed the sender to drain fuel directly from the bottom of the tank. What I saw was reassuring. Tank has no corrosion. 10 month old fuel looked like new. Took 4 gallons out. No water that I can tell. I had added Stabil and ~8 gallons to top it off about 6 months ago.
Should know soon if it is a problem.
Old 05-13-2015, 08:39 AM
It's a trap...
Me too, hopefully this week.
Old 05-13-2015, 11:06 AM
Kartoffelkopf
Spenny_b's Avatar
Have used old fuel to persuade a reluctant BBQ to cook me my food. That was a giggle, my daughter laughed her head off.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 05-13-2015, 03:01 PM
