Sweeten it up before it goes into the car
That was the request.
It was quite a trip for the month. Some. Pictures and explanation to follow Thanks for looking at my post Bruce Arrival ![]() Oil seepage on the main galley ![]() Disassembly ![]() Aftermarket cams w it ha nice street grind
More pictures
Pictures of the Alucil cylinders, virtually all streaked
[img]http://forums.pelicanparts.com/uploads24/image1429222721.jpg[/img You can see them numbered ![]() PO said it did smoke
More pictures
All the up loads didn't take
#3 ![]() ![]() The rod says its 10 O'clock ![]() Second thought, maybe 9 o'clock
Someone has been in it before
You can see the 574 sealant around the studs and on the seal of the #8 bearing
![]() #8. Bearing with sealant ![]() All bearings were factory numbered
Cleaning parts and pressure check oil cooler
Got to enjoy the tool quality, Stomski Racing oil cooler pressure tester
Schleprock
Nice job, as always, Bruce. Shame to see an engine that's so clean inside (must have used good oil and changed frequently) and has great looking main bearings but messed up cylinders.
Great use of the muffin tin too I will add that one to my list of garage tricks for sure!!!How many broken head studs, three?
Kevin L '86 Carrera "Larry" |
Case cleaned
Safety Kleen then pressure wash with super clean gets the nooks and crannies
![]() ![]() Heads are back. New exhaust valves, 12 guides, it was a smoking engine I figured the wasted cylinders was the problem, turned out everything was. ![]()
The 9 Store
Michael's engine? I told him it's in good hands.
Got to love the 574
I prefer to subassembly as much as I can before assembly including setting the valves when building up the heads.
Crank buildup using the Clevite rod bearings
Crank is polished and flowed because of the #3 bearing being a concern.
Layout the bottom end
![]() Still needs 574 on seal flanges
Assembly
I install the bottom studs after the pistons are in place. It gives my hands more room for inserting the pin clips.
![]() New rings on a choice set of Mahle P&Cs ![]() With new studs installed
Heads install and finishing the long block
![]() ![]() ![]() ![]() ![]() The last post on this build as it was only for the long block. Next long block will be a 3.0, I'm considering a crank drive for a 3 prong CD so it can install in mid year car more easily Bruce |
Schleprock
Nice job as always Bruce. What's the black coloring on the cylinders' exterior?
Just the nature of the Mahle cylinder I guess and I didn't clean them in chemicals as there was no oil or sediment on them. I just ran safety Kleen while I was using the scotch bride on the Nikisil inside.
Bruce |
Schleprock
Ok that's weird on the cyls. I've got a set of '85 3.2 Mahle cyls that are bright aluminum. The alusil cyls on my former '87 were dull gray but not blackish like that.
So I thought yours might have been coated with something like this stuff BBE Heat Emitting Coating | Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings
Not that I know of, they were just dark. The history of the car was good, a major dealer had it but when we got it on the lift and some window cleaner there was cold pipes.
The top end rebuild showed several severely burned valves. The cams showed the rockers riding the back of the cam because valve lash was too tight Bruce |
Schleprock
Riding the back of the cam, meaning since the lash was too tight the rocker pad would ride on the "uphill" side of the base circle where one would expect little to no follower contact since the valve should be closed?
Speaking of burned valves, it made me think of a friend's valve guide I recently saw. '87 3.2 with 170K that doesn't use hardly any oil (surprising) & had a previous top end around 2000 with 100K on the clock. So I would guess this picture is a case of the guide being starved of oil from stem seals that do too good of a job sealing the stem? Sorry to hijack but just thought i'd ask your opinion.
The white Teflon seals do too good a job of sealing. I can remember the suggestion was to use the white ones in combination with the brown but the machine shop said throw out the white ones.
As I recall there was 4 or 5 burned like in the picture. The owner keeps them on his office desk because it was so unusual. Bruce |
Schleprock
Thanks for the info. The guide I pictured was sealed by a Teflon seal
