Worn out Nikasil, Replace all?
Doing a rebuild on a 2.7 CIS and have one cylinder that has worn through the coating in one spot at the top of the ring travel. All of the other cylinders look fine and should take a hone. The pistons all need replaced as the top ring grooves are way out of spec. The app is a stock reliable rebuild.
My first thought is to find one good serviceable Niki and replace the pistons with new JE's. My question is are the rest of the cylinders ready to cut through the plating making this a limited life rebuild? That is not my intent. |
Arent there places that can re make the nikasil surface? Seems like that would be good insurance. If one went through, ate you wondering how strong and thick the others are? I really think nikies are the coolest thing since whatever, but the cost!
I would NOT hone a Nikasil cylinder unless you need piston-to-cylinder wall clearance. If the bores are worn, you can send them to US Chrome in Wisconsin for replating.
You should have your new pistons on hand before doing this as they will need one to complete the finish honing.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Yes, that's exactly my concern. I don't want to get 20k more on this car to find out that another bore has worn through. That being said I'm not fond of spending 3k for a new set either if these will be fine. The bore gauge says they are in spec, but the one that is cut through is also in spec so…. ?
You could also just send the cylinders to EBS Racing for replating and buy a set of Pistons from them to be fitted.
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
Do you guys have a approximate price that they charge to plate and hone to fit a set of 6 cyls? I've looked at a couple of sites that do this including US which I've seen bad reports on, and the charge I see is somewhere between $200-300 each. At the higher price, with a set of new pistons, it is approaching the price for a set of new pistons and cylinders. EBS doesn't have pricing on this that I could find on their site.
I'm not trying to go cheap on this motor, but cost IS a factor. I think I know the answer but what is the deal on the QSC sets? Is this cheap off-shore stuff or is it just fine in a summer cruiser?
Otif has a set of Ps and Cs for $300.00. A couple of busted fins but . . .
SoyRacer, thanks, I believe those are an Alusil Kolbenschmidt set. Wouldn't want to put those in this build used.
I have a good set of 2.7 Mahle Nikasil pistons and cylinders. PM me if you are interested in purchasing them.
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
DIRECT LINE 775 825 7729 E-mail: troy@ebsracing.com I was given a price of about $900 to bore and replate 6 cylinders for a 3.2 to 3.4 conversion.
Hugo Last edited by Bird911; 07-09-2015 at 06:32 AM.. |
Actual costs: In 2012 EBS replate and bore 6 cylinders 3.6 to 3.8L = $ 894 JE Pistons and Goetze rings = $940 EBS staff are very helpful = satisfied customer. Regards, PS: 46 hours on race engine = still going strong
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine Last edited by Sboxin; 07-11-2015 at 10:41 AM.. Reason: additional information added |
I am rebuilding my 2.7 cis motor right now and I asked my machinist and some other Porsche motor heads and they did not recommend JE pistons on a stock rebuild. They said the motor won't last long. I have used JE's in water cooled racing applications and they are great, but you freshen up the motor often. I purchased new nikasil p/s's for longevity. I still have my old nikasil cylinders that may be O.K. if you need one.
Schleprock
What do they recommend if not JE?
Kevin L '86 Carrera "Larry" |
Schleprock
Good point.
. I was wondering if we'd hear an endorsement for Wossner or Omega or Wiseco or CP or whatever!
Try not, Do or Do not
Wossner makes an exception product as well as CP. I have used them both with top results. No experience with Omega and poor results with Wiseco. The Wiseco experience is dated so perhaps they have a usable product as well. Back in the day, choices for air-cooled Porsche pistons was limited and Mahle was really the top choice but as the world progresses, other manufactures have improved their products and now offer top quality and sometimes better options for competitive prices.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
IMHO, nothing lasts as long as Mahle pistons do so thats my first choice when longevity and durability are top priorities. Naturally, when one needs special compression ratios or configurations, JE, Wossner & CP are alternatives as long as one doesn't delude themselves into believing they will last as long. We do have Mahle Motorsports make custom applications specifically for us, however those are contained to the bigger sizes; 100mm & larger.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 07-11-2015 at 11:00 AM.. |
So I wonder if we could talk a little more about the original subject of my post? How do the Niki's seem to fail? Do they progressively wear until they are worn through the plating, or do they cruise along not really wearing compared to the relatively soft rings and pistons, until they overheat, or what?
The taper on early cylinders will tell you wear. Nikasil is about .005" thick. If you measure more than .0015 to .002" taper look for a different set. The surface anomalies is pretty self explanatory. Grooves, pits and hot spots are dealt with on a case to case basis. Ovality is interesting. Although Malhe calls out a spec of around .004" that is really deceptive. In fact, meaningful ovality can only be measured under pressure. Use of a torque plate is the only way I know of to accurately measure ovality. In talking directly to the techs at Mahle, they suggested that an out of round cylinder can be brought back by "pranging" them. That's right kids, strategically smacking them with a mallet. RA factor is something I know quite a bit about. Early on, in an attempt to justify reusing cylinders, I did a study on piston/ ring and cylinder longevity and the effects of RA factor. From :do I need to hone this? Quote:
How many engines have you built and tested using these ("inferior" my word not yours) pistons?
