IMR-Merlin's Avatar
I used this.
I have some tick coming from the drivers side bank, but nothing you wouldn't expect from an air cooled engine.
It's a little tight to get on some of the studs on the bottom of the engine, but it gives you a "no guess" reading on the true gap.
Old 07-14-2015, 05:07 AM
Brew Master
cabmandone's Avatar
The feelers are the .0025 and .0030. I just bought a set of feelers at Autozone that had those two on it for about $6.00. I haven't had any trouble using the standard feelers to do the backside valve adjustment.
BTW, the set you asked about from Amazon would be fine. You don't need 12" feelers to do the backside adjustment.
Old 07-14-2015, 07:53 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by cabmando View Post
... You don't need 12" feelers to do the backside adjustment.
You young kids... Just wait until you get 55
Who Will Live... Will See
Old 07-14-2015, 09:29 AM
Gunga Galunga
doublebuffle's Avatar
Originally Posted by IMR-Merlin View Post
I used this.
That's sweet. I'm guessing that you are pulling the rocker away from the valve stem with your finger?
Old 07-14-2015, 09:37 AM
Gunga Galunga
Many appreciations.
Gunga Galunga
Many appreciations.
Old 07-14-2015, 09:46 AM
IMR-Merlin's Avatar
correct, you push and pull to get the measurement. Push, ZERO indicator and then pull....
Old 07-14-2015, 11:46 AM
Gunga Galunga
Did another Valve adjust. Car now sounds great until fully warmed up. Tick remains when warmed up.
Old 09-06-2015, 05:06 PM
It could be worn out bushings on a single rocker or two
Bruce
Old 09-06-2015, 06:22 PM
Gunga Galunga
I could not find a spec. on rocker play (in the axial direction). The was about 1mm movement on all of the exhaust rockers IIRC. I had to be careful to only "rock" them in the rotational direction. I ordered a real stethoscope, so I will be investigating further on Wednesday.
For the record, if you have a catalyst, it will be need to be removed for Cyl. 1 & 2 while using the Stomski tool. It is a breeze though... awesome.
I was also happy to see that my "feel" for dragging the feeler blade had got me very close on most of the valves. Others though, were way off. Observing my last job (with the .004 gauge), I noticed that my tightest valve was .004". This should be useful information knowing that I -thought- I had a medium-high level of drag with the feeler.
Old 09-07-2015, 04:26 PM
Gunga Galunga
Really though it's not a huge deal... an "engine out" is planned for the winter to replace the aging fuel system. The "while you're in there" should be interesting to watch
d/dx
Timing chain
Fuel injectors
Fan/alt rebuild
Head machining
Completion of A/C and CC delete
surface rust repair of engine compartment
sound pad replace
etc...
Old 09-07-2015, 04:31 PM
