Chain fence eating turbo
Dumbest question I think I've asked. Can you see broken rings with a borescope?
I have my 3.2 intake off my 3.4, and I was wondering if I can see a broken ring or not using a borescope.
I've used many back in the day on F15 jet engines, but never in a reciprocating.
Why I'm looking into, is I developed mild blowby after a overboost (hit 30PSI) mishap. Just want to prove what I think has happened.
Old 07-25-2015, 04:50 PM
No, but you may be able to see scoring on the cylinder walls using the spark plug hole to go in.
Old 07-25-2015, 06:31 PM
Broken rings will generally remain encapsulated in the ring groove and stay captured between the piston and cylinder wall. The only way you can see broken rings with a borescope through the spark plug hole is if the piston has failed badly...
Old 07-25-2015, 06:33 PM
Nikasils will get scored? Figured the coating is tough enough this wouldn't occur? I don't think I've had enough detonation to blow the crown(s) since the plugs looked pretty clean - meaning no missing ground straps or chunks of aluminum bits on the plugs.
Old 07-25-2015, 06:42 PM
My 79 3.3 had some when I tore it down a few weeks ago.
Old 07-25-2015, 06:55 PM
You think you ran it for quite awhile?
Old 07-25-2015, 07:11 PM
No, I purchased the car a few months ago, previous owner put about 5k on it in 25 years.
It didn't run right, did all the usual plugs,wires, cap & rotor and run the valves. I found seven broken head studs, got 23 out of 24 removed. Ended up splitting the case and found more problems and now Ollies machine shop has most of the engine.
I'm now waiting for their evaluation and estimate.
Old 07-25-2015, 08:37 PM
Banned
Cory, you probably already know this, but you can more or less verify broken ring(s) by doing a leak-down test on all of the cylinders and listen for hissing in the oil tank, and/or engine drain plug hole, if you find cylinders with higher than normal leakage.
Old 07-25-2015, 09:53 PM
Surprisingly, broken rings do not always reduce leakdowns so that's not a reliable test.
The only real way to know is by disassembly.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-25-2015, 11:51 PM
Ronnie, to what Sir Steve said, made me think of a borescope. Heard people have fine leakdown, but still found broken rings.
Of course, the gap between the crown and cylinder is so tight, figured it wouldn't work.
But, thought maybe there was a slim chance someone knew something I didn't.
Old 07-26-2015, 05:51 AM
abit off center
cgarr's Avatar
When I had broken rings there was an increase in oil usage:
______________________
Craig
G2Performance
Old 07-26-2015, 08:10 AM
My engine leaks so much, I wouldn't know Craig. HEHE
Old 07-26-2015, 12:49 PM
Banned
Cory & Steve, I didn't know that - thanks for the schooling.
Old 07-26-2015, 07:05 PM
My memory is terrible, but when I hear something that seems to defy physics, I generally remember. Having broken rings with good leak down seems crazy, but have heard members experience this here.
Old 07-26-2015, 07:11 PM
PrimeMvr's Avatar
Broken rings definitely scored my Nikasil cylinders. One to the point of needing replating.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 07-27-2015, 09:43 PM
I Wonder
mgro1959's Avatar
Broken rings will eventually cause damage and scoring. The fact that there is more then one a leakdown test may prove OK as long as the damage is recent. As time goes by scoring on the cylinder will affect the sealing of all the rings even if they are not broken and of course oil consumption will start to increase. Would have to be a good scoring. If there is oil leakage then your plug could start to foul. I drove a Toyota 4x4 22r for 26 years. One time I was cruising along and suddenly alot of clattering in the engine and then stopped. I pulled over checked it out and finding nothing continued on my way. Over the next 6 months this would happen give me a heart attack and then go away. A boroscope would have told the tale. Finally the engine on its last tired legs got me home for the last time. That day I was blowing oil out of every orfice. When I pulled it apart the banging was the piston breaking apart. The truck ran well until it started breaking into the last ring land and then it oil ring. I basically had direct passage to the sump from combustion chamber. Good old 22r. Goodluck Thanks Rob
Old 07-28-2015, 10:25 PM
beancounter
jwasbury's Avatar
^not that there's any doubt when Steve says it, but I can confirm this from personal experience. I found broken rings on 3 cylinders when I rebuilt my '79 930 engine. Two had good leakdown and compression numbers:
The "bad" cylinder was #6. Compression was about 10psi down vs. the others, and leakdown was 40%. Surprisingly the engine ran very well, no noticeable smoking. Oil consumption was a bit high (one clue) and the car had a pulsed puffing of vapor from the oil filler neck (another clue).
#6 in addition to broken rings had a deformed crown. Ring lands were deformed such that one was tight and the ring could not rotate, and another was very loose so the ring could flutter. You can also see the oil cooked on the piston crown of #6 above the top ring. An obvious difference between that piston and the others, that's where the blow by and oil consumption was occurring.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 07-29-2015, 05:39 AM
Jacob, how did the cylinders looks? Any scoring. That thing looked like it ran awhile in that condition.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-29-2015, 02:30 PM
beancounter
jwasbury's Avatar
It possibly ran for years in that condition. The cylinders all looked decent IIRC. They measured slightly out of factory spec, but there wasn't any nasty looking surface damage, and the crosshatch was intact. I put new cylinders in anyway because I increased displacement to 3.5, as that was my plan all along I didn't spend a lot of time inspecting them to be honest. I gave them to Brian B (RarlyL8) when he was putting together a mock up "mule" engine to test fit his parts to.
Jacob
Old 07-29-2015, 04:25 PM
Ok, thank you Jacob. Good to know my precious cylinders (if a ring or two or three!) has a chance of not being trashed.
Old 07-29-2015, 05:08 PM
