totle's Avatar
Need help, Piston squirters modification
Hi,
I have a 1971 2.2 911T that came with a 914-6 project I bought from California.
I was told the engine was upgraded, but owner did not know what upgrades it had. It was built by a former employee at vasek polak in hermosa beach
I have taken the engine apart, and it has S-pistons, S-cams, webers, and Mahle nikasil cylinders.
I want to do the oil bypass modification and install oil piston squirters.
My friend has a machine shop with all kinds of fancy CNC machines.
Does anyone have a description of how to drill holes for the piston squirtes?
Would be grateful for any help here
BTW, if anyone has the matching chassis nr, I will be willing to sell it to help make a matching number car back to life
Engine model/number: 911/07 ,#6109506
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 08-05-2015, 02:13 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Ask cgarr (Craig) here on the forums. He's done that exact job (both the piston jet bores and the oil pressure bypass modification) on several older 911 cases.
Kevin L
'86 Carrera "Larry"
Old 08-06-2015, 10:20 AM
totle's Avatar
Thank you Kevin. I will send him a PM
Trond R.
1986 944 Turbo
Old 08-06-2015, 02:54 PM
