Is a 3.0 930 oil pump interchangeable with a 3.3 930
Hi guys
Just wondering if anybody can assist with this question.
Old 02-05-2015, 05:29 AM
They are interchangable but the 3.0 turbo pump is merely a 4 bar pump, too small as we have seen with the 3.2 which uses the same basic pump.
Bruce
Old 02-05-2015, 06:22 AM
Ok thanks
Old 02-07-2015, 09:53 PM
You will need to clearance fit the pump in the 3.0 case and use the shorter 3.3 drive shaft to the intermediate shaft.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 02-09-2015, 12:44 PM
H-viken's Avatar
Is the article number of the shaft mentioned above 93010714300?
I'm planning on putting a 3,3L pump in a 1978 SC case. As far as I understand this does not require modifying the case, correct? All I need is the shaft ref above and a sump plate accommodating the strainer on the new pump?
Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 08-20-2015, 12:15 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Johan,
You do indeed need to clearance the case webbing in a 3.0L SC case in order to fit a 3.3L 930 pump.
That part number you provided is the original number, which has since been superseded to 93010714303
Kevin L
'86 Carrera "Larry"
Old 08-21-2015, 09:35 AM
Walt Fricke's Avatar
Fortunately, clearancing the case is not that hard to do. You can saw off part of what you need to remove, and use a die grinder to finish the job. Of course, a mill will do a nicer looking job.
Old 08-23-2015, 01:10 PM
H-viken's Avatar
Thanks!
911E Coupe -70
Old 08-25-2015, 01:34 PM
wndsnd's Avatar
Here is a 2.7 with big pump and stubby intermediafe shaft.
1973 914-6 Conversion
2.7, crank fired, twin plug.
2006 997.1 Carrera S Cabriolet
Old 08-27-2015, 05:55 PM
