Try not, Do or Do not
What the "L", Supertec 2.8
Here's is a new engine build for a 68, soft window 911"L" Targa
Numbers matching case Bored for 92mm cylinders 2.8 Liter twin plug 9.5:1 3.0 oil pump flow mod Case by-pass mod Oil squirters Plugs pulled and threaded Carrillo Rods Case mod for cross drilled crank 70.4 crank cross drilled Stud holes formed for Supertec head studs ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 05-09-2015 at 03:06 AM.. |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Project Addicted
Beautiful....
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
beautiful work Henry
81 sc 3.0 turbo wb coupe |
It's a trap...
What is the pink looking jig for in the fifth pic of the third post? Is that a piston ring?
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
![]() It is an electric piston ring trimmer. It's used to custom fit rings by adjusting the ring gap to the desired measurement. For years we used the hand crank method but this little tool allows for incredible accuracy and speed as well.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 05-05-2015 at 09:17 AM.. |
It's a trap...
Yes, that. Cool tool.
Vintage Owner
True engine porn! Looks amazing.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Very cool Henry! A VERY lucky guy is getting that engine!
Careful what you wish for... |
WOW , thanks for sharing Henry. That is just beautiful.
Very cool! Quick question if I might, Henry? I don't think I've ever read about this mod? What's going on here?
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
I would rather be driving
He is drilling the case for the cross-drilled crank. Notice the larger oil galley hole and the grooved bearing on #5.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Some people groove the crank as illustrated on our SuperCrank but for street use we find grooving the bearing easier.
Nice! I did notice the bearing on #5 was different. I just wasn't sure why the case mod. Please keep it coming. I'll be working on my case soon. Need to get a sealing kit from you , Henry. Will call...
Constitutional Liberal
A small correction just for clarity: the modification in this engine is on the # 4 main bearing.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Jim is correct. The bearings are counted from the flywheel forward with the thrust bearing bearing # 1 and the nose bearing being # 8.
