Try not, Do or Do not
Henry Schmidt's Avatar
What the "L", Supertec 2.8
Here's is a new engine build for a 68, soft window 911"L" Targa
Numbers matching case
Bored for 92mm cylinders
2.8 Liter
twin plug
9.5:1
3.0 oil pump flow mod
Case by-pass mod
Oil squirters
Plugs pulled and threaded
Carrillo Rods
Case mod for cross drilled crank
70.4 crank cross drilled
Stud holes formed for Supertec head studs
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-02-2015, 09:22 PM
Henry Schmidt
Ph: 760-728-3062
Old 05-02-2015, 09:31 PM
Project Addicted
Beautiful....
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 05-03-2015, 06:26 AM
Henry Schmidt
Ph: 760-728-3062
Old 05-04-2015, 07:48 AM
Henry Schmidt
Ph: 760-728-3062
Old 05-04-2015, 07:57 AM
atcjorg's Avatar
beautiful work Henry
81 sc 3.0 turbo wb coupe
Old 05-04-2015, 08:15 AM
It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
What is the pink looking jig for in the fifth pic of the third post? Is that a piston ring?
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 05-05-2015, 06:09 AM
This thingy?
It is an electric piston ring trimmer. It's used to custom fit rings by adjusting the ring gap to the desired measurement. For years we used the hand crank method but this little tool allows for incredible accuracy and speed as well.
Henry Schmidt
Ph: 760-728-3062
Old 05-05-2015, 09:14 AM
It's a trap...
Yes, that. Cool tool.
Old 05-05-2015, 10:20 AM
Vintage Owner
Jack Stands's Avatar
True engine porn! Looks amazing.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-05-2015, 03:56 PM
Henry Schmidt
Ph: 760-728-3062
Old 05-05-2015, 07:07 PM
Henry Schmidt
Ph: 760-728-3062
Old 05-05-2015, 07:13 PM
Very cool Henry! A VERY lucky guy is getting that engine!
Careful what you wish for...
Old 05-05-2015, 07:54 PM
Emo993's Avatar
WOW , thanks for sharing Henry. That is just beautiful.
Old 05-06-2015, 04:55 AM
tharbert's Avatar
Very cool! Quick question if I might, Henry? I don't think I've ever read about this mod? What's going on here?
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 05-06-2015, 07:51 AM
I would rather be driving
jpnovak's Avatar
He is drilling the case for the cross-drilled crank. Notice the larger oil galley hole and the grooved bearing on #5.
Old 05-06-2015, 08:23 AM
When we cross drill the crank (a mod that adds oil flow to the crank to feed rod bearings #2 & 5) we groove the bearing for constant oil supply. We also increase the volume of oil to the bearing/journal by increasing the diameter of the feed hole.
Some people groove the crank as illustrated on our SuperCrank but for street use we find grooving the bearing easier.
Henry Schmidt
Ph: 760-728-3062
Old 05-06-2015, 08:30 AM
tharbert's Avatar
Nice! I did notice the bearing on #5 was different. I just wasn't sure why the case mod. Please keep it coming. I'll be working on my case soon. Need to get a sealing kit from you , Henry. Will call...
72 911T 2.4 MFI
Old 05-06-2015, 09:30 AM
Constitutional Liberal
Turbo_pro's Avatar
A small correction just for clarity: the modification in this engine is on the # 4 main bearing.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 05-06-2015, 10:22 AM
Jim is correct. The bearings are counted from the flywheel forward with the thrust bearing bearing # 1 and the nose bearing being # 8.
Henry Schmidt
Ph: 760-728-3062
Old 05-07-2015, 08:36 AM
