Robert Espeseth's Avatar
Bolt pattern, head to cam tower
I will make a fixture for surfacing of cylinder heads (3.0/3.2)...does anyone have a dimensional sketch of the bolt pattern of the studs and guide pins? Please share if you have, thanks
Robert
Old 09-28-2015, 10:28 PM
If I am understanding correctly...You want the bolt pattern for the Heads to Cam Housing??
Hopefully I have what you need.
Cheers
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 09-29-2015, 01:55 PM
Robert I chopped up a defective cam tower maybe 30 years ago and am still using it.
If I make a new one I will send you the file but for now I am a little busy.
kan du glemme gamle norge
Old 09-29-2015, 07:11 PM
Thanks for your reply...maybe my request was a little unclear, this is what I'm looking for:
[IMG][/IMG]
Old 09-29-2015, 10:58 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Agreed with racing97. Use a junk cam tower to do most of the work for you. All you need is a plate to connect the hunk of cam housing to the lathe.
https://www.youtube.com/watch?v=XE2M2UUq_Ww
I have a junk housing if you need one.
edit............ Even creative John at Costa Mesa R&D uses the tried & true hunk 'o housing https://www.youtube.com/watch?v=dncyBPHCKyQ
Kevin L
'86 Carrera "Larry"
Old 09-30-2015, 09:58 AM
Thanks Kevin, that's a clever solution to this, will keep that as a plan-B. My plan-A is to use a steel disk I have that suits my Lathe well...will give very high precision I think, just needs to drill the needed holes in it.
Robert
Old 10-01-2015, 12:12 AM
You will need some lateral adjustment some years are not concentric to later years centering will be an issue if you make it solid to the lathe.
Old 10-01-2015, 07:46 AM
Important point, thanks. Will try to make a fixture that can be moved around a little in the Lathe to get it centric.
Old 10-01-2015, 01:39 PM
