gumba's Avatar
rsr distributor cap for Andial twin plug
Does anyone who anything about this cap, rsr distributor cap on ebay. I've seen a couple of listings for this. New Porsche 911 RS RSR Carrera Twin Plug Distributor Cap | eBay
I'm chasing down a high rpm miss in my 930 3.5 twin plug currently running an Andial RSR 12 plug distributor. The cap & rotor have about 13K miles of use. This uses the black cap.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 10-07-2015, 07:37 AM
This is a Marelli Cap as fitted to the Maserati 3500GT and to the 911R on the S121A Distributor and the 2.8RSR with a Marelli S121B Distributor.
They have been re-manufactured by the Maserati Club International for the last few years along with a compatible Rotor Arm.
They are normally about $270 so $200 is not a bad price.
I believe that the Andial Dizzy Conversion used a 3.0RSR Dizzy cap which is Bosch rather than Marelli and is potentially incompatible with the S121A & B Type caps.
The last time I spoke with Andial they had both black and Brown Caps in stock and on special offer.
The Bosch Cap is 3 lug but I am not sure if the diameters and heights are the same as the Marelli and it is an expensive experiment to find out.
RSR911.de in Germany make a replica Bosch 3.0RSR Distributor with cap and rotor but I am not sure if they sell caps and rotors separately.
If you have a Marelli dizzy you can also fit a late Jaguar XJ12 Cap but you will need a different rotor which I believe can be obtained from Burnham Performance.
Jag caps can be had for around $75
Old 10-07-2015, 08:29 AM
gumba's Avatar
Thanks, I have the 3 lug Bosch. I didn't know I could still gets parts from Andial. Anyone know what the life expectancy of the cap & rotor are. They were installed in '06 by Andial, and have about 13K miles. I paid about $1100 for the cap & rotor back then.
Harold
Old 10-07-2015, 09:41 AM
Andial is LONG out of business, now.
Porsche Motorsports bought the name so if you need the Bosch RSR cap and/or rotor, you might contact them to see if they can source them for you since Bosch Motorsports no longer has them.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-07-2015, 04:23 PM
356RS's Avatar
I have a few NOS caps & rotors if needed.
Mark Jung
Bend, OR
MFI Werks.com
Old 10-08-2015, 11:11 AM
Kartoffelkopf
Spenny_b's Avatar
Originally Posted by gumba View Post
.....I paid about $1100 for the cap & rotor back then.
?!?!?! Bloody hellfire! Just for the cap and rotor arm?
...wonder if somebody has 3D printed one yet?
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 10-10-2015, 06:03 PM
gumba's Avatar
This guy seems reasonable (relatively speaking). shop
My goal is to sort it out, then swap over to a Electromotive XDI.
Harold
Old 10-10-2015, 06:14 PM
