How do you separate cases when jugs rusted
I've dismantled an old 1969 911 engine and got it to the cylinders and cases stage. I can't get any of the pistons to move so I have no way to separate the cases.. Any advice??
Thanks....
Old 10-27-2015, 11:34 AM
#147 of 2096
I saw a picture the other day on which the owner cut the cilinder with a grinder.
#147 of 2096
Old 10-27-2015, 07:49 PM
SoyRacer's Avatar
I use a hole saw. Start it on center with the pilot bit, get the saw cutting, remove the bit and then cut down - through the piston - and around the wrist pin. A 3" hole saw usually does the trick.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 10-27-2015, 08:19 PM
I have had to do this several times. I use a die grinder with a heavy duty cutting wheel to cut a slot about 3/4 of the way down the cylinder being careful not to damage the case or the piston. I then use a chisel and a heavy duty hammer to split the cylinder open from the top. This frees the cylinder from the piston and allows the cylinder to be removed from the case, usually in several pieces. Most times it is not necessary to do this on every cylinder as only 2 or 3 are usually the offending stuck ones.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-28-2015, 05:05 AM
I had to split all 6 of the cylinders on my 2.2 using an angle grinder with a thin cutting disc. I used a pry bar to separate the piston from the cylinder. It was a lot of work but I managed to save the pistons only to find out that all of the rings were stuck.
__________________________
'18 Macan S - my turbo Porsche
previous Pcars
'58 356A coupe, '00 Boxster S;'95 993 Polar Silver/Chestnut;'08 Cayman S;'70 911E
Old 10-28-2015, 05:17 PM
safe's Avatar
If you tilt the engine on the side you could probably free the rings with phosphoric acid.
Magnus
Old 10-29-2015, 01:44 AM
Thanks...
I'm going to try some of the methods you described..
Thanks for the help..
Old 10-29-2015, 09:45 AM
bgyglfr's Avatar
How badly are they rusted? I've been able to loosen them before by turning the engine on the side and soaking them with marvel mystery oil and then tapping them with a hammer and slide each cylinder off individually.
70T 2.7RS spec.
68L coupe
Old 10-31-2015, 07:56 AM
Kroil
Rotate the engine on its side and soak the P and Cs with Kroil. Vibration helps, and patience...is necessary. I just freed up a 356 engine that was partially submerged in a flood. A bet and beer was involved. Took two weeks, but it is now free.
Speedo
Old 11-01-2015, 07:38 AM
Straight shooter
Lapkritis's Avatar
Coca Cola ...
maybe add a little heat to the jug too.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 11-02-2015, 07:29 AM
bgyglfr's Avatar
I once saw an old school mechanic use candle wak on bolt threads. The theory was that if you heat the bolt the wax would get sucked into the threads like solder and help them break loose. Never tried it myself.
70T 2.7RS spec.
68L coupe
Old 11-02-2015, 07:59 PM
Engineer of profanity
924CarreraGTP's Avatar
I think both kroil and/or phosphoric acid are both a good start. In a pinch I would resort to WD40 before getting any saws out. Saws get radical at times, but other times they are 100% needed. With that 2.2 I would be very careful and precise. Berrymans makes a very high grade chemical dip that works wonders on things like this. I watched it melt rust once in front of my eyes.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 11-02-2015, 10:58 PM
