Missing Parts
This is not what you expect to see this early in the tear down. i wonder if the original owner knew the motor was down on power. Haha
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
Crusty Conservative
Well, the cast iron rocker was designed to be the weakest link in the valve train, right? Looks like this one worked
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
You have it because the owner realized compression was low....
Bruce |
Chain fence eating turbo
Hope you don't have a bent valve leading to shattered rocker.
I keep thinking I'm going to find it somewhere but no luck yet. Pretty much every fastener and cover was glued together on this guy so lots of patience to get it apart. I'll post a few more pics later especially if I find the rocker swimming through the motor somewhere.
Looks like #2 big end got a little warm...
Wow!
'71 914-6 #0372 '17 Macan GTS |
#7 main has seen much better days. Everything else shows normal wear. This little guy got abused!
Kartoffelkopf
Christ almighty....what a train smash of an engine.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
It's a 914 ...
Wow that's impressive. Lucky the rod didn't exit the crankcase ...
Air Medal or two
Motor mysters engine ?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
