DSPTurtle's Avatar
Missing Parts
This is not what you expect to see this early in the tear down. i wonder if the original owner knew the motor was down on power. Haha
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 11-01-2015, 10:37 AM
Crusty Conservative
silverc4s's Avatar
Well, the cast iron rocker was designed to be the weakest link in the valve train, right? Looks like this one worked��
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 11-01-2015, 01:26 PM
You have it because the owner realized compression was low....
Bruce
Old 11-01-2015, 01:45 PM
Chain fence eating turbo
Hope you don't have a bent valve leading to shattered rocker.
Old 11-01-2015, 03:21 PM
DSPTurtle's Avatar
I keep thinking I'm going to find it somewhere but no luck yet. Pretty much every fastener and cover was glued together on this guy so lots of patience to get it apart. I'll post a few more pics later especially if I find the rocker swimming through the motor somewhere.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 11-02-2015, 05:14 AM
DSPTurtle's Avatar
Looks like #2 big end got a little warm...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 11-07-2015, 10:06 PM
Cairo94507's Avatar
Wow!
'71 914-6 #0372
'17 Macan GTS
Old 11-08-2015, 06:50 AM
DSPTurtle's Avatar
#7 main has seen much better days. Everything else shows normal wear. This little guy got abused!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 11-08-2015, 11:01 AM
Kartoffelkopf
Spenny_b's Avatar
Christ almighty....what a train smash of an engine.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 11-08-2015, 04:31 PM
It's a 914 ...
stownsen914's Avatar
Wow that's impressive. Lucky the rod didn't exit the crankcase ...
Old 11-08-2015, 05:36 PM
Air Medal or two
afterburn 549's Avatar
Motor mysters engine ?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 11-09-2015, 12:37 AM
