How to build 2.7 for more pwr
Iam considering doing a 75' 2.7 Ltr in a 914,..but I want HP/TQ from that eng,..without going to crazy,..what cams are needed,.Iam sure carbs are where the pwr is so what would be the best set-up,..looking for reliable but a strong runner,..with lots O torque,..??? Thanks FM
Old 11-20-2015, 07:43 PM
My friends call me Phish
I am running a driveable hot 2.7 in my '66 912 and it flies
2.7 Shuffle Pinned, by pass, upgrades, etc
40 Webers
9.5 to 1 JE Pistons
E CAM! (all low end, with a short geared 902 tranny)
Single Plug
The dizzy has a custom vaccum line that pulls through the manifolds
SSI
M and K exhaust
Front mounted oil cooler.
If you are heading to the Orange County area, I will definitely give ya ride in it.
Old 11-20-2015, 10:17 PM
About 3 years ago I built a hot rod for a guy.
Started with a straight 74 case, bypass, case savers, 92mm JEs @9.5, solex cams, already had basic PMO so called for the needed mods, SSIs.
Great, fun, light weight car with very responsive acceleration.
Bruce
Old 11-21-2015, 03:56 AM
al lkosmal's Avatar
https://www.youtube.com/watch?v=EWB99lddFew
regards
al
RGruppe #669
http://www.x-faktory.com/
Old 11-21-2015, 07:29 AM
I am in the same position. I just purchased a 1974 2.7L engine complete with the CIS fuel injection for eventual installation in my 1973 914. I currently have a 2056cc type IV in the car that I rebuilt with a web-cam and Megasquirt engine management. I really like the diveability and tunability of the MS FI and ignition control compared to the dual IDF Webers the car had when I bought the car. Because of that my thoughts for the 2.7 are:
- the engine already has case savers installed for all of the head studs
- a "top end" rebuild was done a short time before the 2.7 was replaced by the original owner by a 3.2
- I will am planning a complete tear down of the engine to check all clearances re-seal the case.
- on the rebuild, assuming I have Mahle nikisil cylinders, I will replace the pistons with JE 9.5 cr pistons and the cam with a 964 re grind.
- exhaust headers and a free flowing muffler
This combo was identified by Wayne D. in his rebuilding book as being compatible with the CIS FI system while providing a nice horsepower boost. Optomistically hoping for a 30-50 hp gain for a total of 180-200 hp with good midrange torque and excellent diveability.
Old 11-21-2015, 10:27 AM
I haven't been involved in 911 engine work since,.oh 2006,..when I did a top end on a 3.0,..but I did not have to split the case,..Iam sure a 3. anything is out of my price range now,..but with a 2.7 can they be rebuilt affordably or should ya hold out and pay way more for a 3 ltr ??? Thanks FM
Old 11-23-2015, 08:28 PM
Mick_D's Avatar
rebuilds usually cost about the same on a 2.7 as they do on a 3.0 I am finding.
Old 11-23-2015, 10:06 PM
Not even close if its done properly.
The difference is case preparation and IMHO, that's not optional if you wish to have a reliable engine. Expect to spend anywhere from $2K to $3K (over a 3.0 litre), depending on precisely what is done.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-23-2015, 10:34 PM
Mick_D's Avatar
If by case preparation you mean the installation of case savers and center-boring, does that really add up to $3k?
Old 11-24-2015, 07:26 AM
tharbert's Avatar
It's certainly over $2k especially if you include the crank and rod work: case halves decked and align bored, spigots leveled, case savers in mains web long bolt and head studs, squirters cleaned, oil bypass and sourcing a 4 rib mag pump if needed, dipped and cleaned...and then there's the race mods if so desired.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-24-2015, 07:44 AM
Absolutely accurate right here.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-24-2015, 08:04 AM
Mick_D's Avatar
And none of that ever needs to be done on a 3.0?
Old 11-24-2015, 10:34 AM
VERY VERY rarely, unless its a high RPM, high BHP race engine making 105-110 HP/litre.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-24-2015, 11:04 PM
Yea,..the 2.7 is a soft case and they tweek,..3.0 strong Alum.rarely need it but I know a 3.0 is to much for me now wasn't then paid 2500 for a complete 81',..I may go LS1...you could almost do the complete conversion for 4 K,..I kinda don't want to,..but 300 ponies in a 914,..???
Old 12-01-2015, 07:44 PM
Vintage Owner
Jack Stands's Avatar
Check Henry Schmidt's Supertec website and he lists some prices. Not cheap, but you get what you pay for.
I have one of his engines in my 914-6 conversion, and it's an absolute blast to drive (~200hp at the rear wheels - S cams, Weber carbs, RS P&Cs).
Case prep is probably the most important part of the whole project, so do your homework.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 12-07-2015, 05:51 AM
Buy a 3.0
Old 12-07-2015, 06:08 AM
JmuRiz's Avatar
Re: 2.7 budget rebuild...what kind of hp is available w/o head work?
I have a '74 2.7 that was previously rebuilt (has oil fed tensioners, 930 valve covers etc) but I'm told it was a stock-ish rebuild for a '77 car. It was a low mile rebuild as the PO went the 3.6 route rather than build the 2.7 to more power to fit a PCA class.
If the heads are stock-spec, would it make sense to have them redone and improved or keep them as-is and just do a p/c and cam swap?
Would I need to do case work if the case looks good? Just wondering what I'm getting into before tearing it down....or sell it and look for a 3.0?
Thanks for your input.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 12-07-2015, 09:36 AM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Subscribed
Old 12-30-2015, 04:31 PM
