Subscribed
I do think that your MFI/EFI adapter design is simple and elegant. Nice solution for those wanting to retain the cool, early MFI bits and looks, while incorporating modern engine management. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Banned
Cup plenum at the top of it, coupled with a 3.8 993tt engine, it produces 875hp with one hell of a throttle response, have had it working for a few years now without a hitch, and besides if it is good for Cosworth in their Singer engines, it is definitly good for me! |
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
3.8 993tt is the big ticket items you're looking at here
Chain fence eating turbo
Yes so 3.8 plus some bigger snails and etc they'll make 800+
![]() ![]() The spacing is the same as Webers/Zenith Cars so an Air Filter Box from these carbs will fit directly and with an SCRS Type Intake could work in the short term. We have decided to ditch the fuel rail and try to make it look a bit older in style using hose. I have sourced an Polypropylene Braided hose that looks similar to the Tecalan Hose used on some of the RSRs and we have drawn up fitting to seal the injector and a manifold block to connect the fuel lines. This will sit in the same position as the MFI pump and also connect the pressure regulator. We will try to re-manufacture the MFI Filter Housing as a 'plenum' and pump fuel to this and then by-pass back to the tank. |
I would rather be driving
Nicely done.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Racer
This low butterfly, tall carbon fiber stack system is installed on my 3.9L 964 RSR. Need to re-dyno things after a recent rebuild of the motor with a cam change, but on the first trip made approx 385 HP.
It's straight through, equal length. The throttle bodies are unknown. Perhaps Porsche Motorsport.
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
seen similar with this RSR type track car locally, 3.5L.
Racer
Sweet. What's going on with the air filter/intake on that thing?
custom made carbon airbox, makes the powerband much nicer he said (much better mid range than previous apparently)
Racer
My system is rod actuated, yes.
I agree with your comment about rain hats / covers on a daily driver, remember this is a pure race car. Here is a pic of the linkage. Please ignore the wonky return spring; this is a pic of the car when I got it and quite a few things were put together incorrectly. ![]()
Actually, the system appears to be cable driven. I assume this is the case from the gearbox to the rod block shown. Good looking setup by the way.
This is the data we need to determine if the slight port angle on Weber style manifolds will have an impact on total power / flow. Alas, I do not have this data.
I think that despite David Vizard's flowbench crusade that many simple flow measurements are not the complete picture.
I an accept that in flow terms a straight port and runner may give the highest flow. I would have thought that a single cylinder of a 3.0 litre engine that produces 300BHP at 7500 rpm would manage with an air flow of about 80CFM at WOT. This correlates quite well to the calculated 70CFM air needed to burn the fuel required to develop 300 BHP assuming a BSCF of 0.5lbs/hr/hp that we would use to size the injector. It would be very interesting to know the flow capability of the inlet system complete with the valve at the maximum opening. |
Racer
Yes, my apologies. It is a cable to the engine itself.
