I am my 911's PO
Thanks for the warning. Not obvious it would travel there.
I wonder how much fine stuff get blown through the crankcase vent to the oil tank. I imagine it's just a tornado of oil mist and pulverized metal. |
I am my 911's PO
Take a look at at these main bearings. Surprisingly little embedded metal, it seems.
Yes the mains actually look descent, not scratched through the rotation.
Bruce |
I am my 911's PO
Are the mains good enough to reuse?
There is 2 thought processes here. One to fix the fault and the other is to rebuild because you're there. The nice thing about the Porsche design is you can fix the fault.
You ll need a rod, P/C, head, rocker. Check the oil line in the carrier for damage from the rocker. Remove the mains and mark exactly where they came from in the case to be reused. Cleaning will be the biggest problems. Oil galleys in the case, galleys in the crank, how scratched up inside is the oil pump? Etc, etc Bruce |
Oh my.
I think Bruce is correct. Cleaning is going to be at, or near, the top of the "difficult steps" list.
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
I am my 911's PO
junk getting into lubrication system
You said it, Tom. It's going to be a nightmare.
The old race cars had a filter called a "grenade" to keep debris from the external oil system. It's a magnesium casting with a stack of fine mesh filters inside that attached to the motor in place of the internal cooler. I think the name was partly due to its shape but mostly due to it role when an engine "grenaded". Here's one on a 906 (just aft of #6).
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
I am my 911's PO
Spun bearing, right?
That's what they look like
Bruce |
I am my 911's PO
I'm sure there was a cheaper way to learn that. Wikipedia, maybe.
I am my 911's PO
Here's the rod journal. No grooving I can detect with fingernail. Not glassy smooth like the others but not rough. Mikes out near low end of wear limit.
Oh, I could have showed you several pictures but you asked after the fact...
Polish out the journal and see if you can straighten it out making it usable then get coated bearings to build up the thickness. Mike on three different angles to check for oval Bruce Last edited by Flat6pac; 01-16-2016 at 04:30 PM.. |
I am my 911's PO
Someone suggested the crankcase spigot can be welded to build it up and machined back to standard height. Is that feasible? The damage is shallow (about 1mm at deepest) and extends about 1.5 inch.
A machine shop will heliarc the low spot and flycut it up to standard.
At that point you might consider using the thicker fiber base gaskets to fill in better. Bruce Last edited by Flat6pac; 01-17-2016 at 11:10 AM.. |
I am my 911's PO
crankcase repair
OK, I've been slowly working my way through the process of assessing damage, locating replacement parts and cleaning, cleaning, cleaning.
Here's the crankcase after repairs. The repair inside the spigot is obvious, there were also small repairs to the top of the spigot.
I am my 911's PO
metal in intake
The horror! So sorry to see this misfortune, best of luck getting her back in track shape!
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
I am my 911's PO
The clean up has been an enormous task. The whole oil cooling and circulation system had to come out to be flushed, swabbed and ultrasonically cleaned. In the process, I explored areas I've never seen - here's the inside of the air box. ![]() Note the metal flakes still present after flushing with carb cleaner and flooding twice with solvent. I had to open it up to really clean it. The good news is I found my air leak. ![]() That's the o-ring that seals the throttle body to the air box protruding.
You found your air leak, so it's all been worth it......in the end
Bruce |
I am my 911's PO
Yep, finding the air leak is a plus. I'm also having the crank drilled for better oiling and installing a 964 oil pump. Not sure I can stand this much fun again - at least not soon.
