Alan L's Avatar
cylinder size matching query
I have a set of 5 new P/Cs, and have sourced thru EBS Racing the possibility of picking up a 6th. The group height can be matched but I have a couple of other queries ;
Does the cylinder size need to match?
And presumably it would pay to try and get as close a match in piston group weight - using the +/- symbols on the bottom of the pistons. Presumably if we can't get a group weight match, I should be shooting for a heavier group weight if possible (to reduce down later).
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 01-18-2016, 05:31 PM
Alan
When sourcing a single P&C pair it is important to match the new piston weight in grams to your other five pistons. You also want to match the cylinder height (or height group) to your other cylinders. Finally you want to make sure the piston to cylinder clearance of your new pair is acceptably small.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-19-2016, 05:00 AM
Alan L's Avatar
Hi Tom,
Thanks for the reply. I can get a group height match and I certainly intend to get a match in weight, one way or other. But I note the cylinders are also grouped in size (Diameter) - is it necessary as well as Gp height and piston weight, to match the cylinder size - or can I have a mix of say 5 size 0 and 1 size 1?
regards
Alan
Old 01-19-2016, 09:32 AM
Alan
With used pistons and cylinders it is necessary to measure the piston and cylinder bore diameters because of wear on each. The diameter size groups stamped at the factory are not as meaningful on used parts.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 01-19-2016, 09:48 AM
Alan L's Avatar
Hi Tom,
These are all new.
Regards
Alan
Old 01-19-2016, 10:25 AM
If you are buying new, then the diameter group of the piston should match the diameter group of the corresponding cylinder. You can have variation between the piston cylinder pairs (ie. you can have (5) group 0 pairs and (1) group 1 pair). The small difference in size group between cylinders will be insignificant.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 01-19-2016, 01:24 PM
Alan L's Avatar
OK, great. Thanks Tom. Appreciate your input.
Regards
Alan
Old 01-19-2016, 06:38 PM
Alan L's Avatar
Interestingly, the new P&C's are one group height (6) and one group weight, only.
Simplifies things a bit. Unless you have gp5 cylinders.
Alan
Old 01-19-2016, 08:50 PM
Try not, Do or Do not
Henry Schmidt's Avatar
911 Vintage Parts has nearly 1000 pistons and cylinders in stock.
They also stock reconditioned cylinders. Your change of matching you set are pretty high.
Call Ken @ 760-731-4911
911vintageparts.com
info@911vintageparts.com
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-20-2016, 05:52 AM
Alan L's Avatar
Whoo - wish my shed looked like that. Thanks Henry - EBS Racing has new ones they sell individual also. Was trying to match 5 other new ones. Looks like we are in luck.
Regards
Alan
Old 01-20-2016, 09:55 AM
