My friends call me Phish
Weber Sync Help
I followed the PP's Weber Carb sync details
Pelican Technical Article: "Carburetor Adjustment, Balance, and Tuning" - 911 (1965-73) -
All the throats are sync'd perfectly, the car idles fine and there's no lag on acceleration when I am on it.
The issue comes into play at 3200-4000rpm when just cruising, I can feel some hesitation and carb pop until I accelerate a bit. There's Rarely there is a exhaust backfire.
Any suggestions or is it just trial and error with the mixture?
BTW - The car ran great before I cleaned and and rebuilt the carbs. (a couple of the o-rings were leaking that's why I rebuilt them).
Old 01-28-2016, 12:43 PM
rsscotty's Avatar
Carb guru
Try this link....Paul is a master with these carbs.
Performance Oriented
Old 01-28-2016, 01:05 PM
Gordo2's Avatar
Mid-RPM Carb Stumble
The link to Paul's page is some of the best info I found for helping me get my PMO's tuned.
I tuned my carbs with the help of a wideband sensor - which lets you know exactly what's happening with the mixture at various RPM's / loads. Highly recommend getting one to read & record your AFR for fine tuning and troubleshooting.
As a heads up - your issue may be challenging to resolve: its occurring in the RPM range where the carbs are transitioning from the idle circuit to main circuit.
From your description, it sounds as if your leaning out a bit as the idle slowly transitions to your mains. You probably don't notice the hesitation when accelerating hard because the accelerator pump/nozel dumps fuel into the carbs masking what could otherwise be a lean spot.
Recommend trying to adjust your mixture at 3k RPM's to get the engine running smoothest at that RPM - then give it drive. You may find this ends up quite a bit on the rich side at idle though.
Good luck, enjoy the carbs and the learning curve.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 01-28-2016, 07:21 PM
Gordo2
That's a great idea, I will adjust my mixture at 3k and see what happens. I will also look into the wideband sensor.
Old 01-28-2016, 09:17 PM
In addition to what's been mentioned already, the symptoms could be a result of your linkage being off. You may have to adjust the short arms or the mounts themselves so that the throttles are opening evenly.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-28-2016, 09:32 PM
