Alan L's Avatar
Should we start a sweepstake?
I'm with valve train. The suspense is killing me. Pull the valve covers. :-)
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-17-2016, 11:16 PM
My money is on badly set valve clearance!
Old 02-18-2016, 04:47 AM
Any news yet?
Old 04-06-2016, 04:12 AM
Diagnostic tool........
Use a mechanic's stethoscope to locate and isolate the offending noise. It could be any of the previously mentioned culprits. So you need to systematically identify the root source and cause of this problem. Keep us posted.
Tony
Old 04-06-2016, 03:22 PM
valves...I just did my own rebuild and I got the same sound...Mine settled after awhile and I readjusted the valves.
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 04-06-2016, 04:09 PM
It was the fan blade rubbing. He figured it out.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 04-06-2016, 08:02 PM
The Dude abides...
bigel's Avatar
Are you 'his' spokesman?
'03 Carrera 4S
Old 04-07-2016, 10:41 AM
Kartoffelkopf
Spenny_b's Avatar
Really? I wouldn't necessarily have guessed that....surely they'd be witness marks in the yellow paintwork? (or are there? perhaps they're out of shot?)
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html
On Instagram (along with other stuff) as @spenny_.b #spennybengineproject
Old 04-09-2016, 06:41 PM
