Loud knock after rebuild
After a very long rebuild I started the engine - and this is the disappointing sound. I thought everything went well but there is an obvious problem. Does anyone have an idea what this could be?
https://www.youtube.com/embed/Otrvvb5kOTg Thank you, Bill |
abit off center
Specs on the rebuild? at first I was thinking piston slap?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Maybe an excessive game(set,play) of valve. I hope that your valves do not touch your heads of cylinder.
Sounds like valves. Better check clearances again. Maybe some were set at wrong crank position.
if so, prob not fatal - just real sloppy. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
My friends call me Phish
is it too loud for an exhaust leak?
I had one bolt missing on one of my exhaust flanges and it sounded like that. Does it get louder when you rev it ? |
non-whiner
An intake leak can also make that noise.
"Too much is just enough." |
Sounds mechanical, not a leak.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Free minder
I vote for bad cam timing. I had the exact same noise and went back to check the cam timing, which was significantly off on one side. The good news is, you can retime the cams with the engine still in the car.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Straight shooter
Have heard similar from clutch area at idle; slight rise in idle and things would quiet down. Use a stethoscope to isolate the offending area before tearing into anything.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I am with Alan L here more like valve area, hope its not to bad for you
Bill after all your work, cross fingers, |
What the heck, I'll throw my guess behind exhaust leak. Hard to tell from just the video.
Valve train. Pull the cover and check the clerances.
Try removing the fan belt, you never know.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Check tensioners. They have a tendency to lose prime after sitting awhile.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. |
probably valve train noise... do a VERY PRECISE & ACCURATE compression & leak down tests... repeat the tests a second time to validate your findings... your answer lies within these tests...
if you do not know how to do these tests accurately and most importantly how to interpret the results and how to listen for where air blow by is happening, then ask for help... good luck...))
I live for 911 tweaks... |
I'm going with worn rocker and rocker slap
Bruce |
The simple answer will be to first pull some valve covers and check the slop in the rockers.
Alan
I had exactly the same after my rebuild. I had accidentally set one of the valve clearances at .040" instead of .004"! My excuse is that they are difficult to get to and the proper tool is pretty useless! After a reset all was quiet.
Chain fence eating turbo
I wishing you an easy fix like a rocker, but man that sounds like a main bearing.
Fingers crossed for you, I'd be *****ting bricks myself. Of course my valve covers would have been off in minutes of hearing that. |
Have you tried a stethoscope? I had an engine with piston slap once I could tell exactly which one it was, it sounded almost like a bell with the stethoscope. Also, try rotating it over very, very gently, you should be able to feel the rocker action and maybe sense something. Good luck.
Runge Eleven david@rungeeleven.com www.rungeeleven.com Porsche 911 Corrosion/Collision Repair Specialist Last edited by David Liam; 02-17-2016 at 10:45 PM.. |
