wprater's Avatar
Case perimeter stud installation
How can I determine if I have the correct stud for installing into the case perimeter of my 1978 SC case.
One is missing and Im hoping to be sure I have a correct replacement. Does anyone know the measurements of the stud? I know its an M8 x 1.25, but not sure of the total length, and where does the non-threaded portion need to sit?
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 02-14-2016, 05:30 PM
SoyRacer's Avatar
I have several boards with stud length and location but I have made them as visual templates.
Photo of location and engine code and I can give you a length.
Note: most upper and lower studs are the same length.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 02-14-2016, 05:40 PM
VFR750's Avatar
My 3.0 SC Perimeter Fasteners.
Of the (22) locations on the perimeter, how many/which one are missing studs?
Per the picture
WHITE: (19) studs on RHS,
YELLOW: (2) studs mounted on LHS
RED: (1) bolt near the bottom front of the engine.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 02-14-2016, 05:53 PM
wprater's Avatar
nice chart!
Im missing the stud for #6 in your picture.
Im also missing the bolt #17.
Specs on both, with be great!
1990 911 Carrera 2
Old 02-14-2016, 06:50 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The #6 stud is one of thirteen that are M8x32. 32mm is the overall length, not length sticking out after it's installed. I have a bunch of junk camshaft housings that i've pulled the studs from. The lower valve cover studs are M8x35 and I have a bunch of them if you would like me to send one or a few or however many you want. No charge.
The #17 bolt is nothing special M8x45 length and a common 8.8 property class/strength. This should be easy to get at your local hardware store. I've found that Ace Hardware stores have a pretty good selection of basic metric bolts like these.
Kevin L
'86 Carrera "Larry"
Old 02-15-2016, 07:09 AM
wprater's Avatar
Thanks, Kevin!
Im going to measure some studs I found around the shop. Can I use Loctite 574 to install them?
1990 911 Carrera 2
Old 02-15-2016, 12:59 PM
wprater's Avatar
just measured and #4 and #5 were total/exposed 49/32.3mm and #7 52/35.3mm
I found a stud for #6 that's about the right fit.
and some Permatex red high strength thread locker.
1990 911 Carrera 2
Old 02-15-2016, 04:04 PM
wprater's Avatar
test fit shows my stud is too short?
1990 911 Carrera 2
Old 02-15-2016, 04:14 PM
You have a full nut, you're not going to get any more hold. The only one that needs to be longer is the ground wire attaches on #4.
Bruce
Old 02-15-2016, 05:18 PM
wprater's Avatar
Bruce
I've been looking for that ground wire too! can I attach it after I mate the case and let seals cure?
anyone got an extra?
1990 911 Carrera 2
Old 02-15-2016, 05:31 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Sorry I got my measurements incorrect about overall length vs. operable length. Red loctite isn't necessary but it's not going to hurt anything. All of the studs are held in place with a low strength threadlocker that doesn't require heat or a ton of effort to remove the studs.
Just make your own ground wire (if you no longer have yours) with a thick gauge wire and some crimp on eyelets. Then you can make the ground wire go to whichever stud works for you.
Kevin L
'86 Carrera "Larry"
Old 02-16-2016, 12:58 PM
Use high quality marine grade wire and eyelets crimped on the ends if you can. The quality is way better than generic auto parts stuff.
Old 02-16-2016, 04:22 PM
wprater's Avatar
that's exactly what I got! and it even matches my fan and calipers
1990 911 Carrera 2
Old 02-16-2016, 06:56 PM
