-   -   Disassembly Done ... Time To Rebuild 3.0 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/909871-disassembly-done-time-rebuild-3-0-a.html)
mikedsilva 11-12-2016 01:09 PM
What was your valve clearance set to on 1 and 4, when the valves were closed?
arbita1 11-12-2016 01:11 PM
When closed they are at 0.
Trackrash 11-12-2016 01:46 PM
I think you mean valves adjusted at .004", not what the dial indicator was set at?
From what I see in the videos you are looking good.
Are you using the stock tensioners when you did this check? And made sure the chains were tight?
arbita1 11-12-2016 02:03 PM
Oh yea. .004 was the clearance.
I have the mechanical tensioners from smart racing or one of those companies. You can see them below. Chains are tight.
http://uploads.tapatalk-cdn.com/2016...544d97d34e.jpg
arbita1 11-17-2016 06:51 PM
Cam timing is done. Hydraulic tensioners are in. Started installing the exhaust rockers for cylinders 1 & 4 so I can do the piston to valve clearance check one more time.
http://uploads.tapatalk-cdn.com/2016...fd6be1c3cc.jpg
arbita1 12-02-2016 05:47 PM
Making progress. Now installing remaining rocker arms.
http://uploads.tapatalk-cdn.com/2016...6c5dbe15fb.jpg
EDIT ...damn. Just looked at the picture and realized I'm showing off my messy garage. How embarrassing.
arbita1 12-03-2016 02:44 PM
Long block sealed up.
http://uploads.tapatalk-cdn.com/2016...bfa17aa631.jpg
bbturbo 12-13-2016 11:17 AM
Nice work! this thread has been a fun read. I am now motivated to get busy with mine.
arbita1 12-13-2016 11:46 AM
Thanks. Forgot to update with current progress. Starting to bolt on the accessories. Fan and exhaust done. Next to install CIS.
http://forums.pelicanparts.com/uploa...1481658386.JPG
strictly 12-17-2016 01:42 PM
GREAT BUILD,
Just some 2 cents from me, great build though, dont shoot me for the advice.
Your cam olines, your left one looks like its the old one? These are cheap insurance to replace, I would.
And why not set them so the rubber bit is straight, reduces stress on the ferrale (connection between rubber and metal pipe). If you blew a cam o line on the left side (due to over stress of the ferrule where the rubber clamps to the metal), it would be a while before you noticed it with the oil pressure light coming on, due to the amount of oil in the system, and the oil pressure gauge sender being on the right (which could at least give some warning for the right side), by that point your left cam train would be trashed :
You will need to loosen of a the whole line, but after that its fairly easy to put them straight and reduce stress on the connection.
Maybe im just fussy! but i always do it. This is an old engine where I took a pic to show some one else a few years ago :
http://forums.pelicanparts.com/uploa...1482010705.JPG
http://forums.pelicanparts.com/uploa...1482010807.jpg
mikedsilva 12-17-2016 01:45 PM
seems like good advice .
strictly 12-17-2016 01:51 PM
another pic, new cam lines on this one,
http://forums.pelicanparts.com/uploa...1482011426.jpg
arbita1 12-17-2016 02:56 PM
That's a good eye. I'll straighten them out. Thanks.
jbahrami 12-21-2016 08:58 AM
Hi Matt,
Great work you are doing on the rebuild. I have a 3.0 I am rebuilding myself.
If you don't mind me asking, how much did it cost to have the heads rebuilt? Did you need to replace your valves?
Thanks!
Jeff
arbita1 01-15-2017 08:19 AM
https://uploads.tapatalk-cdn.com/201...cb4581870e.jpg
Rebuild complete. Can't believe I finished. Now to reconnect transmission. Replace cv joints. I'm also still waiting on my fuel injectors to come back from cleaning.
mikedsilva 01-15-2017 11:48 AM
cool!
arbita1 01-15-2017 12:56 PM
Motivated today. Cv's replaced.
https://uploads.tapatalk-cdn.com/201...fdae3fbf5a.jpg
mikedsilva 01-15-2017 01:02 PM
I always found it easier, to put the cvs back in , after the engine and tranny were installed...
arbita1 01-15-2017 01:12 PM
I hear you. They can get in the way during engine install. But access to the outside cv is so much easier without the engine in.
arbita1 01-25-2017 06:44 PM
Transmission reconnected.
https://uploads.tapatalk-cdn.com/201...50b066dadf.jpg
Just waiting on a few fuel injectors and this thing is ready to be reinstalled.
