0396's Avatar
Carrillo vs Pauter Rods
I'm sorry if this has been asked. But over the years, I seem to see more and more folks selecting Pauter rods vs the old Carrillo rod. Is it like the oil tread , where one person like X vs another?
Please educate me small brain.
Thanks in advance for your reply.
Old 04-12-2016, 01:01 PM
SoyRacer's Avatar
Carrillo rods - nice Japanese quality, some clearance issues on some combinations.
Pauter rods - Very nice American product, no clearance issues on any combination.
Lots of other reasons but these are mine.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 04-12-2016, 05:11 PM
Carillo - Japanese?
Surely Carillo is owned by Pankl?
Old 04-12-2016, 11:17 PM
It's a 914 ...
stownsen914's Avatar
I asked a similar question a year or so ago. I wondered why Carillo, which I'd understood to be the gold standard years ago, seemed to have been overtaken by Pauter. There weren't any responses indicating any quality issues with Carillo. And there was mention of Carillo being owned by Pankl now. Perhaps customer service is one reason. I haven't worked with either vendor firsthand, but I understand Pauter is good (and better than other vendors in general) in this respect.
There is a fundamental design difference between the two vendors' products. I don't have an informed opinion on this, but I think I have seen more opinions in favor of the H beam design that Carillo uses.
Scott
Old 04-13-2016, 06:45 AM
0396's Avatar
I asked because I've seen a Carrillo rod come apart in a Nissan...the whole engine was toast.
Old 04-13-2016, 08:43 AM
Chain fence eating turbo
Betcha oil starvation rather Carillo quality...
Old 04-13-2016, 09:21 AM
0396's Avatar
Please don't assume, rod broke in half.
Old 04-13-2016, 09:32 AM
At what rpm?
Old 04-13-2016, 12:04 PM
0396's Avatar
I can't answer that, its was an boosted GTR engine. When I asked them about why the rod broke in half...the supplier simply said that they needed a stronger rod.
I tend to think that Nissan motor was not turning say 9 + grand. One rod broke and took out the whole engine. I have Carrillo in another engine...and since I'm looking for a set of rods for a different projects. Thus the question.
Old 04-13-2016, 12:23 PM
I've seen plenty of rod failures and one cannot determine cause without doing detailed forensics.
Rarely are good (Carrillo, Pauter, Arrow) rods are fault for metallurgical issues. In most cases, Human Factors lie at the root of the cause.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-13-2016, 01:50 PM
0396's Avatar
Steve, your probally correct as you build these motors day in and day out. But the motor in question was boosted to produce 1600 + hp. Im not sure if the rods in question was spec to hold up to that level of HP. I think that is why the vendor- they buy direct mentioned that they will need another version of their rods. Only one of six rods let loose.
Old 04-13-2016, 02:30 PM
'But the motor in question was boosted to produce 1600 + hp"
I'd say that may have something to do with it. That's like 4 bar at 7k rpm for a 3.8L.
Old 04-13-2016, 07:16 PM
I'm willing to bet the GTR turned far higher than 7K.
I'm still betting on oil starvation.
Old 04-13-2016, 07:25 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
I built a Ducati 748R engine and used Carrillo rods rather than the OEM Pankl Ti rods (due primarily to cost, the engine was going into an endurance race bike, and the fact that they only weighed a few grams more) - that engine spent over 40 track hours being shifted at 11.5k rpm during my ownership and no problems with the bottom end (this was around 2006 or so). It also did not lose any hp due to the slightly heavier rods (had to have the new, OEM crankshaft ballanced to suit them, however). Probably too much of an apples to oranges comparison to be of much use to the OP, butt just thought I would throw that out there . . .
Old 04-13-2016, 07:59 PM
Most likely, just pointing out the ballpark kind of boost numbers involved.
Old 04-14-2016, 03:00 AM
Originally Posted by chris_seven View Post
Carillo - Japanese?
i recall carillo was an american company many years ago with parts built here. I believe about 10 years ago they started to make there rods abroad and weren't quite the same?
Old 04-14-2016, 06:20 AM
Carrillo Rods are American made I see huge boxes of them at the Blanchard Grinding facility I use and they are still 4340 Forged in Michigan.
There are Chinese look alikes such as Eagle Rods which can be a cost effective in use for Domestic engine kits. Scat is another company the uses the Chinese Rod for their product offering.
regards
Old 04-14-2016, 06:46 AM
0396's Avatar
I would like to add that this shop only uses Carrillo in there motors. But somehow this one rod of six happened to let go...as it cracked in half. For you that think oiling issue would cause the rod to break apart - please educate me.
This shop still uses the Carrillo rods on their lower HP buils. But I'm sure after talking to Carrillo they recommend another configuration of rods for their high HP application.
Old 04-14-2016, 08:58 AM
I would think they "Carrillo" would recomend an Alumium Rod in Boosted applications the likelyhood
of a miss fire or premature ignition of the end gas in the cylinder would complicate things greatly.
Al Rods are being used in Boat racing, Lucas Oil series off road etc. as well as the Shock Absorber for Drag racing.
regards
Old 04-14-2016, 09:26 AM
regards
Thanks for clearing that up
Old 04-14-2016, 03:22 PM
