steve 911T SWB..
help Rocker arms question
hi, we have a problem with the final tuning of my engine
i have a 2.0T engine and we did the 2.2S P&C upgrade with also 2.2-2.4 heads i bought E cams and now we have a problem tuning the rocker arms....... it looks like if the srew of the rocker arm is to short to tune it for the exhaust valve !! i do not remember having seen something writen about a change to do to the rocker arms for this upgrade ... any ideas ??? cheers steve |
Were these reground cams? If so then the base circle is reduced-or the stem height
of the valves is short. There used to be cheapo cams out there that had a too small base circle. Not really safe to use as it throws the geometry off.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
steve 911T SWB..
I bought the cams from a member who swapped them for others and they run well in his car.. So would say cams are ok....
steve 911T SWB..
My mechanics says he would need 5mm more on the exhaust valve.... Could it be that the valve is to short? I bought the heads with new valves put in place...
Puny Bird
5mm is a lot
![]() You could use lashcaps.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
It's a 914 ...
I assume the rocker arms were ground/resurfaced? Could it be that too much was taken off the pads?
steve 911T SWB..
Thanks friends, we took a Head out and checked !!! The exhaust valve is 6mm to short...... So ordered 6 new ones
Thanks to all for the help |
