3.0 Piston pin
Need the Piston pin tolerances for 3.0
Bore- Shaft- Clearance fit- I have Waynes book but the above info is N/A tks ed |
Puny Bird
For what? Installing and sizing the small end bushing?
I'd never do it that way. You need to take the rods, bushings and pins you will be using to your machinist. This is a high tolerance slip fit, there should be absolutely no pin rock or slop and at the same time it can't be tight. Not something you want to ballpark. Clearance will be tight, something like .0005"
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 05-01-2016 at 09:36 AM.. |
+1 without a doubt
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
agree with above
still need the dimensional info |
Puny Bird
22mm
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Funny you ask this. I'm going to be dropping my rods at the machine shop for rebushing. My machinist told me he needs a good pin also when I bring them in. It got me thinking how do I know if the pins are good. I looked in Wayne's book and Bentley and couldn't find any info. I was thinking of putting each corresponding pin with each rod and let him decide if he should use one for all or each individually. Maybe I'm over thinking.
Matt. 83 911SC 85.5 944 NA - Sold Last edited by arbita1; 05-08-2016 at 09:14 AM.. |
Puny Bird
The pins are hardened steel, the rod bushing is bronze (alloy), the bushing wears before the pin ever will. So likely your old pin are fine and in tolerance. If you are getting new pins I'd wait till you have them in hand before going to the machine shop.
I didn't reply to the OP because any engine machinist worth his salt has a reference book(s) right at his desk and should be asking for a pin. Also this is not a job you do on a mill, it takes several special machines/tools and experience to do a top notch rod rebuild. One degree off will put side loads on that will prematurely end your engine. Not a 911 but this will give you a good idea of the work involved. https://youtu.be/lzUa8kYLSRU
Mark is quite right that the bushings are the "sacrificial" material.
If you look at your pins now there are two spots that don't ever ride in the piston or rod. they may have a stain even. if you can detect any bump there you've got wear-got a mic?
Functionista
If it helps, industry standard on floating pin type is gravity. Yes, no typo. You let the pin fall through the bushing under its own weight. Slips right through, too loose. Doesn't move, too tight. Slowly moves through, just right. Oiled surfaces.
Of course, comparing the above to brand new Porsche assembled parts would be best. Or if Henry wanders by he might have some input.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. Last edited by manbridge 74; 05-08-2016 at 04:15 PM.. |
Under the radar
Bush new, 22.033 - 22.020mm inside diameter
Clearance 0.020 - 0.039mm I just took an SC motor apart and the original Male piston pins measure 21.996mm
