3.0 Piston pin
Need the Piston pin tolerances for 3.0
Bore-
Shaft-
Clearance fit-
I have Waynes book but the above info is N/A
tks
ed
Old 04-30-2016, 07:54 AM
Puny Bird
Mark Henry's Avatar
For what? Installing and sizing the small end bushing?
I'd never do it that way.
You need to take the rods, bushings and pins you will be using to your machinist.
This is a high tolerance slip fit, there should be absolutely no pin rock or slop and at the same time it can't be tight.
Not something you want to ballpark.
Clearance will be tight, something like .0005"
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 05-01-2016, 09:29 AM
prschmn's Avatar
+1 without a doubt
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 05-02-2016, 04:42 AM
agree with above
still need the dimensional info
Old 05-02-2016, 08:47 AM
Puny Bird
Mark Henry's Avatar
22mm
Old 05-02-2016, 09:04 AM
Originally Posted by Mark Henry View Post
22mm
Tks Mark
22 mm - shaft dia?
Would you know the clearance fit as well?
Tks for your response
Old 05-02-2016, 09:17 AM
arbita1's Avatar
Funny you ask this. I'm going to be dropping my rods at the machine shop for rebushing. My machinist told me he needs a good pin also when I bring them in. It got me thinking how do I know if the pins are good. I looked in Wayne's book and Bentley and couldn't find any info. I was thinking of putting each corresponding pin with each rod and let him decide if he should use one for all or each individually. Maybe I'm over thinking.
Matt.
83 911SC
85.5 944 NA - Sold
Old 05-08-2016, 06:26 AM
Puny Bird
Mark Henry's Avatar
The pins are hardened steel, the rod bushing is bronze (alloy), the bushing wears before the pin ever will. So likely your old pin are fine and in tolerance. If you are getting new pins I'd wait till you have them in hand before going to the machine shop.
I didn't reply to the OP because any engine machinist worth his salt has a reference book(s) right at his desk and should be asking for a pin.
Also this is not a job you do on a mill, it takes several special machines/tools and experience to do a top notch rod rebuild. One degree off will put side loads on that will prematurely end your engine.
Not a 911 but this will give you a good idea of the work involved.
https://youtu.be/lzUa8kYLSRU
Old 05-08-2016, 08:28 AM
prschmn's Avatar
Mark is quite right that the bushings are the "sacrificial" material.
If you look at your pins now there are two spots that don't ever ride in the piston
or rod. they may have a stain even. if you can detect any bump there you've
got wear-got a mic?
Mark
Old 05-08-2016, 03:33 PM
Functionista
manbridge 74's Avatar
If it helps, industry standard on floating pin type is gravity. Yes, no typo. You let the pin fall through the bushing under its own weight. Slips right through, too loose. Doesn't move, too tight. Slowly moves through, just right. Oiled surfaces.
Of course, comparing the above to brand new Porsche assembled parts would be best. Or if Henry wanders by he might have some input.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-08-2016, 03:46 PM
Under the radar
Trackrash's Avatar
Bush new, 22.033 - 22.020mm inside diameter
Clearance 0.020 - 0.039mm
I just took an SC motor apart and the original Male piston pins measure 21.996mm
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-08-2016, 09:45 PM
