Need help identifying 3.2 main bearings
Does anyone know what the replacement part number is for 930.132.61? I'm pretty sure they're standard inner dia / .25mm outer dia
any info would be appreciated
-Rich- 1984 911 Track 1985 911 Track/Autocross |
It would be very unusual to have a 3.2 case linebored oversize-have you measured the bore?
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
I don't have a bore gage but I did measure the old bearings and new bearings with a caliper. Putting the bearings mated together and then measuring the I.D. / O.D. / & thickness of the bearing...it all points to a .25mm larger O.D.
I was hoping someone would confirm the old part number and then offer up the new part number
Are you sure the number doesnt have a 101 after the 930? The part number is too short.
If those are available be prepared for the price-won't be cheap
83 911 Production Cab #10
Item 18: Porsche Crankshaft (102-00) NLA on PP but they where $100 x 12
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
