HArd cross over oil line issue
Hey Gents
As part of my rebuild I got an aftermarket hardline that goes from the engine case and fastens on to the passenger side timing chain box. Well the one I got has no bracket to fasten to the timing box. Not a big deal as I can put on a clamp easy enough, but when I went to install it I realized it is not even close the the bottom of the timing box , although its close when overlayed on the other pipe I realized im a good two inches towards the back of the car. Anyone ever run into this ? I was just going to go to a pipe bender guy and ask him to bend it in a little more as the oil connection is a mid air connection anyway. I think currently it might not even reach my oil coupler in the car . Any thoughts ? Thanks
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
okay did a little more research and realized my mistake .. I ordeed the wrong on .. I ordered the turbo one by accident .. gonna see if I can bend it a little more and use it if it doesn't interfere anywhere.
The turbo pipe that you bought has a bend around the kidney of the turbo. The pipe from right corner to the thermostat should be the same as the SC and turbo that drops a rubber hose at about 45 degrees to the new connecting pipe.
Bruce |
Thanks Bruce , it looks close but when I bolted it on it sticks out behind the timing cover by about 2 inches , im thinking a bit more bend is in order .I wll try and post a pic.
There is a lot of lever there, be careful not to crimp it
I'm going to try and use a conduit bender and some heat. What could possibly go wrong
![]() I figured I have the old one as a backup
Bruce et All
I little bending is in order for this line ? im thinking it should line up with the timing chain case . ![]()
where did your exhaust studs go?
1971 911T (Tangerine) 1973 911T (Light Yellow) 1978 911SC -- "Northy" 3.2 twin plug 1990 911 Carrera 2 |
Not installed yet intentionally
![]() Watching this thread, as I have seen these issues before. Cut & weld and then re-plate has been my method when these oil pipes do not fit. ![]() Len
update .
I did a test fit ( and glad I did ) . The reason the pipe does not come close to the timing cover is because the initial bend out of the case is not correct. the reason I know this is the pipe hits the heat exchanger when I install it . I either cant install the pipe. of the exchanger on the side where the pipe goes into the case. If the pipe took a true 90 degree angle where it came out of the case it would not interfere with the exchanger and be tucked more so it would align with the exchanger. I attached a pic but i'm not sure if the pic shows its not quite at 90 degrees. My buddy is going to re-weld the bracket that broke off my original pipe and i'm just going to use that . I might take this pipe to a hydraulic shop and see if they can bend it a little more at that point. Nothing to lose at this point, and i'm just curious as to whether I can get it to fit. ( just to be clear I did NOT buy tis part at our host !! )
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) Last edited by theiceman; 05-14-2016 at 10:35 AM.. |
Counterclockwise?
You could also just have a flexible line made up at a hydraulic shop.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
