Member 911 Anonymous
DRACO A5OG's Avatar
Question Cam Shaft Installation Lube?
Hey Fellas
So read up on installing Cam Shafts, it stated I need to use Lube like Swepco101 Moly Grease ( CV Joint Lube ).
Question I have is has anyone tried using Dow Corning MOLYKOTE gear oil additive or something similar or better?
I use the stuff for my 915 gear box sticks to every metal part, for the engine, any residue that remains will be caught in the oil filter and wondered if it would a good idea to use for the installation of new to me 964 Cams? Of course I will change the oil after 500 miles or less.
TIA,
Jim
'85 Carrera Targa
PCA/POC
Old 05-19-2016, 11:26 PM
prschmn's Avatar
You should be fine with that. Most important thing is to NOT let the engine idle at the first start.
The hydrodynamic wedge that lifts the rocker off the lobe is speed dependant-higher revs=
more film thickness.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 05-20-2016, 04:54 AM
DRACO A5OG's Avatar
Whoa, scary.
Thanks for the Heads Up, Master Mark!
So, where should the RPM be and how long for initial start up and "break in"?
'85 Carrera Targa
PCA/POC
Old 05-20-2016, 08:49 AM
prschmn's Avatar
Fear not Draco.. Most cam manufacturers say at least 1500 minimum-I'd shoot a bit higher.
say 2000 or so. Ideally it's best on a new engine to just drive it-gently ASAP. You need some load to seat rings which one does want to be careful with on a Nickasil cylinder.
More revs aren't going to hurt cam break in either.
And of course the standard disclaimer that idling is the worst thing to do to a 911 engine.
Mark
Old 05-20-2016, 11:30 AM
DRACO A5OG's Avatar
Ah ha!
Most grateful, funny how it is not mentioned in the Bentley/videos/threads or I may have missed it.
Oh yes, I will be driving her very gently the first 500 miles and change the oil soon after.
I am just swapping the cams & seals/orings, new rsr seals for the rocker shafts ( there are leaking ), refurbed rockers. I am on the fence about the springs or just save my new ERP springs for a real rebuild down the road.
My main reason was to verify timing as it is suspected the previous rebuild, timing was not set properly then recently a rocker shaft walked out on me
Again Thank You Master Mark!
'85 Carrera Targa
PCA/POC
Old 05-20-2016, 11:36 AM
theiceman's Avatar
i remember that thread , did you end up replacing both cams ? was there any pitting ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-20-2016, 11:52 AM
DRACO A5OG's Avatar
In the process, just waiting to receive some loaner tools from a gracious Pelican
I have pretty much all the parts and ready to go.
I will be posting the 3.2 Cams once I have them removed.
'85 Carrera Targa
PCA/POC
Old 05-20-2016, 11:54 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Dow makes great products and we have documented our use of Dow 55 on all o-rings in 911 air-cooled engines but for bearing surfaces we use Supertec SpeedLube.
After 15 years of development and testing it is now offer exclusively through Supertec Performance and 911 Vintage Parts 760-731-4911
We also offer SpeedLube Bearing Life to fortify oils used in air-cooled engines, both turbo and NA.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-20-2016, 03:44 PM
Under the radar
Trackrash's Avatar
Originally Posted by DRACO A5OG View Post
Ah ha!
It's outlined in Waynes book and every cam supplier, I have ever seen, says no less than 2000 RPM for the first 20 minutes.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-20-2016, 04:04 PM
DRACO A5OG's Avatar
Outstanding!
Thank you G!
'85 Carrera Targa
PCA/POC
Old 05-20-2016, 04:08 PM
