Member 911 Anonymous
DRACO A5OG's Avatar
Question What the Heck is this and did it come from the Engine?
So I was preparing to install my D-side cams and after I removed my Carrera oil line from over the chain box to the cam tower. I started to clean the area and found this weird thing just sitting at the bottom of the #3 rocker/valve port.
WTF?
Is this part of the engine? I can not imagine PAG would use plastic inside the engine, right?
I tried to fit it into the banjo bolt thinking it was some sort of innerds of a check valve??? Nope, no fit.
I was working on my step-son's Infiniti, maybe it dropped and bounced into the engine? I was pretty careful but poop does happen
TIA fellas,
Jim
'85 Carrera Targa
PCA/POC
Old 07-04-2016, 06:54 AM
911 2.2 T targa
Dowel pin of some sort. The cam-shaft to sprocket one should be 6mm in diameter and the nr.8 bearing should be 8mm. So it is not one of the obvious.
Old 07-04-2016, 10:03 AM
DRACO A5OG's Avatar
Both cam pins in place
Did not split case.
I think it is an errand tool or debris from the Infiniti ��
'85 Carrera Targa
PCA/POC
Old 07-04-2016, 11:38 AM
The pin that holds the #8 nose bearing in place
Bruce
Old 07-04-2016, 01:23 PM
DRACO A5OG's Avatar
It's plastic?
But how the heck did it get there with case not being split ?
'85 Carrera Targa
PCA/POC
Old 07-04-2016, 01:42 PM
Puny Bird
Mark Henry's Avatar
Originally Posted by DRACO A5OG View Post
It's plastic?
No, it wouldn't be plastic. I'd say it's not from the engine.
Good thing it's not in the engine anymore right?
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 07-04-2016, 01:51 PM
DRACO A5OG's Avatar
I don't know, the dowel looks like it is metal versus the thing I found which is black plastic material.
900-012-061-00-M100
'85 Carrera Targa
PCA/POC
Old 07-04-2016, 01:53 PM
DRACO A5OG's Avatar
Thanks fellas!
Happy 4th you State Side Fellas :-)
'85 Carrera Targa
PCA/POC
Old 07-04-2016, 01:54 PM
