Member 911 Anonymous
![]() So I was preparing to install my D-side cams and after I removed my Carrera oil line from over the chain box to the cam tower. I started to clean the area and found this weird thing just sitting at the bottom of the #3 rocker/valve port. WTF? ![]() ![]() ![]() ![]() Is this part of the engine? I can not imagine PAG would use plastic inside the engine, right? I tried to fit it into the banjo bolt thinking it was some sort of innerds of a check valve??? Nope, no fit. I was working on my step-son's Infiniti, maybe it dropped and bounced into the engine? I was pretty careful but poop does happen ![]() TIA fellas, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
911 2.2 T targa
Dowel pin of some sort. The cam-shaft to sprocket one should be 6mm in diameter and the nr.8 bearing should be 8mm. So it is not one of the obvious.
Both cam pins in place
Did not split case. I think it is an errand tool or debris from the Infiniti
The pin that holds the #8 nose bearing in place
Bruce |
It's plastic?
But how the heck did it get there with case not being split ?
Puny Bird
Good thing it's not in the engine anymore right?
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
![]() I don't know, the dowel looks like it is metal versus the thing I found which is black plastic material. 900-012-061-00-M100
Thanks fellas!
Happy 4th you State Side Fellas :-)
