Uncertifiable!!!
Uwon's Avatar
How to Bench Test a 915 Trani
I had to drop the motor on my brand new build to deal with what looked like a clutch fork issue but turned out to be a cracked pressure plate.
While I'm waiting to sort things out with the supplier, I have this 915 trani on my bench that I sure would like to test . Is there a particular procedure to bench test without opening the unit?
Thanks in advance.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-03-2016, 08:00 PM
You can work the shifter in all gears, but that won't tell you anything, other than it shifts.
206 637 4071
Old 08-04-2016, 05:43 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Remove the inspection plate and post a pic of the back side of the plate and the internals.
'85 Carrera Targa
PCA/POC
Old 08-04-2016, 08:05 PM
I agree, all you can tell is that it is free to rotate and that it will shift.
If you had a decent size electric motor and an inverter you could possibly zero load spin it to 2-3000rpm but again this wouldn't tell you much.
I used to design/manufacture Transmission test rigs but even a relatively simple rig would be hugely expensive as you would also need to be able to load the unit.
The cheapest way to test it is to stick it in a car.
Old 08-05-2016, 12:42 AM
