Member 911 Anonymous
DRACO A5OG's Avatar
Question Oh the Joy, 3.2 Case Through Nut LEAK?
So I was under the car today and noticed a new drip trail emanating from the nut circled in red D-Side on the engine case. I assume it is a case through nut. Is there an oring behind it that may be leaking?
Not my car, thank goodness but thanks donor from Rennlist
I checked the torque, it is at 25 ft lbs so I am thinking an oring that gave out.
1985 Porsche 911 Carrera Targa - Main Engine Components - Page 3
TIA,
Jim
'85 Carrera Targa
PCA/POC
Old 08-22-2016, 10:14 PM
Yes, that is a case through bolt which helps clamp the intermediate shaft.
The common problem with these, is that the stud pulls out of the other side of the case which makes it impossible to torque. But if yours is at 25lb ft, then that is unlikely the issue. Lucky too, since the only way to fix that, is split the case.
There is no o-ring.. just a washer and nut. Try cleaning the thread, spread some thread sealing compound, then put the nut back on and re torque.
Old 08-22-2016, 11:38 PM
technically , its not a case through bolt. just a stud and nut.. the case through bolts are around the cylinders, use o rings and have pressurized oil flowing around them. just like mikeD said, remove nut, clean it up and install new nut and washer. there I no pressurized oil behind that nut.
Old 08-23-2016, 03:49 AM
DRACO A5OG's Avatar
Oh Perfect, thank you Brothers!
'85 Carrera Targa
PCA/POC
Old 08-23-2016, 06:26 AM
arbita1's Avatar
I've seen a video where the guy recommends to put 574 under the washer of this nut.
Matt.
83 911SC
85.5 944 NA - Sold
Old 08-23-2016, 02:57 PM
Cars Ruined My Life
impactbumper's Avatar
i would use black silicone rather than 574 there.
Old 08-23-2016, 05:12 PM
DRACO A5OG's Avatar
I'll try some 3Bond aka HondaBond/YamahaBond on next oil change.
'85 Carrera Targa
PCA/POC
Old 08-24-2016, 08:24 PM
drola's Avatar
sorry to hijack but i have a question. i have the same issue with the lower dome nut behind the oil cooler. i tried to torque it and right when i got to 25 lbs i felt it pop, meaning it jumped threads inside, which would explain why that nut was loose in the first place. any suggestions?
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 12-06-2016, 08:29 PM
DRACO A5OG's Avatar
I sealed it and it worked, no more drips.
'85 Carrera Targa
PCA/POC
Old 12-06-2016, 11:36 PM
Cairo94507's Avatar
Every once in a while the Porsche Gods smile on you.
'71 914-6 #0372
'17 Macan GTS
Old 12-07-2016, 06:27 AM
"sorry to hijack but i have a question. i have the same issue with the lower dome nut behind the oil cooler. i tried to torque it and right when i got to 25 lbs i felt it pop, meaning it jumped threads inside, which would explain why that nut was loose in the first place. any suggestions? "
Not good. Magnesium case?
Old 12-07-2016, 06:39 AM
Ken911's Avatar
[QUOTE=boosted79;9387050]"sorry to hijack but i have a question. i have the same issue with the lower dome nut behind the oil cooler. i tried to torque it and right when i got to 25 lbs i felt it pop, meaning it jumped threads inside, which would explain why that nut was loose in the first place. any suggestions? "
Not good. Magnesium case?[/QUOT
you could install a heilcoil and reset the stud. If the case is apart then I would use a timesert instead.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 12-07-2016, 10:03 AM
drola's Avatar
case is not apart and trying to keep it that way. i put a double nut on the stud and turned it till it bottomed out. now just waiting for the oring to arrive from our host to try again. i tried to double nut it again to turn the stud out to remove it but it did not want to spin. so hopefully it will stay. i don't think it will be possible to put a heli coil in there without splitting the case, unless it fits through the hole which is slightly larger than the stud anyway. i'll see what happens first before i go that route.
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 12-08-2016, 04:45 AM
Ken911's Avatar
Yeah thats why i was thinking a helicoil might fit, a time sert will not because it has a shoulder on it.
2019 Silverado 6.2L
Old 12-08-2016, 07:16 AM
One a mag case, when that stud pulls and leaks oil, run a 10x1.25 tap in the hole and use a short bolt and aluminum washer. No drilling needed, no damage done. Timesert the stud hole sometime when the case is apart.
206 637 4071
Old 12-09-2016, 07:29 AM
Location: 24 miles from Lime Rock Park. 1 light, 8 Horse Farms, 114 Turns
Make it work
Like he said!
Thanks for sharing your skills
For All these years.
Makes it possible for us do it yourselfers.
Alan
Old 12-09-2016, 09:09 PM
drola's Avatar
This is a great suggestion. Thanks
Do i torque it to 25 ft lbs like the original nut on the stud?
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 12-09-2016, 09:22 PM
25lbs is probably why it pulled. 18 max for an 8mm fastener. The 10mm Bolt trick just needs to be lightly torqued so it seals. It's not holding anything.
206 637 4071
Old 12-11-2016, 06:41 AM
prschmn's Avatar
Too bad that isn't going to work for Drola's problem-great idea for Dracos though!
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 12-11-2016, 08:14 AM
drola's Avatar
why would this not work for me?
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
Old 12-11-2016, 04:40 PM
