Cam Tower
Will a 964 cam tower work on a 3.0liter or 3.2 motor?
Yes but you lol need valve covers to match as the studs are 6 mm instead of 8 mm.
The early 964 castings were used as early as 1988 series but with correct 8mm studs Bruce |
I'm not so sure it's that easy-the oil feed arrangement is different.
Maybe it would be possible to tap the hole in the carrier to accept the 10MM hollow bolt?
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
