Hi, can't find the part on Pelican store. Green o-ring in the case.
My case is bored to 107MM there is a 1.5MM (deep and wide) groove in the case. I measured the Oring at the un-worn section at 2mm thick (same digital caliper from home depot) also, i dont have a groove on the bottom of the cylinder for that gasket. can anyone help?
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera Last edited by pmajka; 09-15-2016 at 07:58 AM.. |
Forced Induction Junkie
You wouldn't able to use a Porsche factory oring anyway. If you did, the oring would stretch and change the material diameter. This would probably result in the oring dislodging. Do you know the manufacturer of the cylinders? I would contact a supplier of those cylinders for the proper oring for that case.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I have the old phone number at home, will call to see if it is still active. cyliners are 102mmID, 107mmOD.
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
You might want to give EBS Racing, Steve@Rennsport or Henry Schmidt of Supertec Performance a call. If it's a MAHLE cylinder, there should be a solution out there for you.
3.8 w/ 109mm cylinder base use a 3.53mm o-ring which is black in color, 999.705.023.41 x6, on these the case is grooved but the cylinder is not.
