New-ish 911SC Targa Owner
pampadori's Avatar
any benefit to filing sharp points on pistons down?
An old wizard dressed like a human once told me that he never built an engine without taking a file to the sharp pointy areas on the pistons to prevent them from becoming little glow rods and causing preignition.
I've only rebuilt one other motor before and It had flat top pistons so it was moot point. On a 911 piston with sharp edges around the valve reliefs, would there be any safety against preignition if one was to smooth those sharp points down some?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 10-18-2016, 07:21 AM
If there was a foreign object in the cylinder running and hitting the piston putting nicks in the face, that's the kind of high points that would glow causing pre ignition.
Bruce
Old 10-18-2016, 07:37 AM
Straight shooter
Lapkritis's Avatar
Yes but difficult to measure... more so on a turbo car in my opinion. Tape the sides and bottom so you don't get dust everywhere. I would work only by hand to avoid mistakes that are more likely with a rotating tool. Work each piston the same with the goal of smoothing rather than removing material, and use a scale to keep weights between all pistons the same. This is good prep in advance of applying a ceramic coating to the piston crown as well.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 10-18-2016, 08:26 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The benefit is more about performance than an actual "hot spot"
We see 5-7 hp by simply rounding the sharp edges of some after market pistons.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-18-2016, 10:51 AM
Walt Fricke's Avatar
Henry - how much does rounding as shown reduce the nominal CR stated by the piston maker?
Old 10-24-2016, 06:57 PM
Our experience is .05 to .15 points of compression. Adding a ceramic coating will replace most of the dome volume removed.
Interesting how you use the term "stated by the manufacturer".
We have found that "stated" compression ratios are rarely close especially with early Mahle.
Our experience has shown Mahle over-estimates CR making accurate performance predictions hit or miss.
Henry Schmidt
Ph: 760-728-3062
Old 10-24-2016, 08:07 PM
Thanks, Henry. The phrasing was not by accident, of course.
Old 10-24-2016, 09:54 PM
